Paniza
Flight distance : 1411801 ft
Hi Mr Menace,
Not as simple as it seems. I gave up on it for now.
Let me see if I can explain...
First, any inverter you use, please go after the "pure sine" ones or you might burn your batteries.
So, to charge 1 battery, using the DJI wall charger, it draws a ton of current from your car battery. The main issue is how to connect the battery with the inverter... for 2 batteries at once, the lighter won't do it... too much.
Also, even for 1 charger, the inverter will eat up your car battery very quickly, be careful.
I have heard from a ton of people that they are using a single charger from the lighter, directly to the battery. That makes sense as it is Pb to Pb charging.
They have one in the DJI store but it is for P2.
Most people are getting the lighter charger from email for less than $20.
Here is my similar post on the same subject:
http://forum.dji.com/thread-32557-1-1.html
Cheers.
