Problem RSC2 with A7III + 24-70GM Vibration
6896 11 2020-11-13
djiuser_9GwbJPKWjwHy
Flight distance : 322615 ft
Vietnam
Problem Ronin RSC2 + Sony A7III + 24-70GM Vibration when Walking Balance complete, excellent app DJI Ronin CHECK walk slowly, both 2 hand with gimbal
I write email to DJI but they don't help anything ! just say check and check.
I go to shop sell me ! they said Gimbal RSC2 can't handle A7III + 24-70GM because heavy ?
Anyone help me ! have same gear as me ! check  Gimbal RSC2 can handle A7III + 24-70GM or not ?
thanks a lot !!!!!!!!!!!
2020-11-13
Vietnam
anyone help me
2020-11-13
AdamFK
I'm having the same issue with my GH5s. My Weebill S doesnt have these jitters...
2020-12-4
djiuser_WvE2fdLKlqsM
Same issue with me... using canon m50 .. footage is not stable ever after balancing proper
2021-1-23
DJI Wanda
Hello there, your combination set up can be balanced on the RSC2: https://www.dji.com/support/compatibility/rsc-2/a7r3
Could you please try to lower the stiffness or increase the deadband on the Ronin app to see if the vibration will decrease?
2021-1-24
DJI Wanda
djiuser_WvE2fdLKlqsM Posted at 1-23 22:20
Hello there, could you please check which axis is shaky or you can send us any footage regarding with the issue you had? We will check with our engineer to see any solutions may help, thank you.
2021-1-24
VictorM
I having the same issue with RS2, BlackMagic 6K, Sigma 18-35mm. Autotune give very bad results with shaky footage and manual tuning help a little. It seems to be a common problem, it there a firmware update coming soon ?!
2021-1-24
Still having this issue with my nikon d5300 and m50 ... app showing excellent balance .. still footage is not stable
2021-1-25
fansd9ad877a
I have the exact same problem. My DJI RSC2 with Sony A7iii and Sigma 24-70 ART lense has micro vibrations in the footage that I didn’t pick up in the recording of it so now I have footage that is wasted and I have left the location!! Not very happy to be honest
The gimbal balances fine, I haven’t made any manual adjustments. I also cannot go into briefcase mode with this setup, triple clicking the trigger does not flip the camera. I also struggle to get into 360roll mode, again not sure why? Making my RSC2 unusable. Any help would be greatly appreciated
2021-4-16
Khadka Dinesh
Nepal
I want canon 90d with 18-135 lens is the best option rsc 2 or rs2
2021-8-1
DJI-RS PM 铁匠
hello , Hello, in our gimbal test, Ronin RSC2 + Sony A7III + 24-70GM works well,it won't Vibrate so much. Did you turn off the stability function of the camera
2021-8-1
DJI-RS PM 铁匠
Khadka Dinesh Posted at 8-1 19:11
I think rs2 can work better
2021-8-1
