kiwichrish
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
You'd have to put a bigger battery in the Phantom.
I'm guessing, but the battery will be 4S1P config at the moment...
You could disassemble the 'smart' end off the battery, and add a connector to the outside of it allowing you to connect an external back to make it 4S2P.
But... More battery = more weight = less flight time.. So doubling the capacity will not double flight time. Maybe add 40-50%..
Also, the Phantom 3 is not designed to carry extra batteries... You'd have to lower the gimbal, and put the battery above it. On-top is not an option as you'd block the GPS.
Once you'd done that the centre of gravity would change, and you can't change the tuning that much on the Phantom 3, so it may not be stable...
End result: lots of risk, not much gain = Too hard. :-)
If you want long flights, built an F550 or similar and experiment with props / battery combos to get max efficiency. Phantoms and Inspire craft are not designed to be tinkered with, they are an out-of-the-box photography platform.
Good luck...
(And If you do decide to hack into a standard pack and modify it.. I never posted this, and I think you're nuts. :-) ) |
