Inspire 2/X7 problem with activation.
1330 15 2021-8-22
krzysando
Flight distance : 2099898 ft
Newly purchased drone. First launch and activation last Friday. The problem is, the X7 camera won't activate. The result is the message: "Camera Sensor Error". Very urgent matter. Can anyone help me?
2021-8-22
Hi, there. I regret the trouble you've been inflicted, we will try our best to help you get it addressed. If it is convenient, could you please provide a picture of the error code?
Beforehand, you can use the following two methods to try to solve the problem.
First, you can try to power off and reinstall the gimbal and camera, and then restart to solve the problem.
Or, after power off, you can use waterless alcohol to clean the gimbal interface and metal contacts of the gimbal interface, then install the gimbal camera and restart the drone.
If the problem still remains, it is recommended to send the drone back to our factory for futher examination. We will try our utmost to help you out.
Here is our repair link for you to check :
https://repair.dji.com/repair/index
2021-8-23
krzysando
DJI Gamora Posted at 8-23 00:13
Thank You for answer.
I really care to avoid sending this camera back. I really need it in 2 days. All the proposed methods didn't help.
2021-8-23
krzysando
2021-8-23
That must have been frustrating for you, I have forwarded this concern to the appropriate department, will look into it and help you get an update soon.
2021-8-23
krzysando
DJI Gamora Posted at 8-23 01:26
Yes it is.
Thank You for help.
2021-8-23
Matthew Dobrski
Flight distance : 1831050 ft
krzysando Posted at 8-23 01:28
Yes it is.
Thank You for help.
Dużo prościej będzie wrócić do sklepu i wymienić drona na taki który działa ...
2021-8-23
Hi there. I am sorry for the difficulties you are experiencing. First, we recommend that you connect to DJI Assistant 2 and provide a screenshot of the current aircraft firmware version. At the same time, you can try to downgrade to the previous firmware version to see if it works normally.
If the problem persists, you can upload App log, update log and flight control data to us via Dropbox/Google drive, and send this link to us.
The path for exporting App Log:
/sdcard/DJI/dji.go.v4/LOG
The path for exporting update Log:
C:/Users/XXXXXX/AppData/Roaming/DJI Assistant 2/upgrade_log
Flight control data can be exported to local via the Assistant 2 App.
We will do further analysis based on these and solve the problem for you. Thanks for your support.
2021-8-23
krzysando
DJI Gamora Posted at 8-23 20:09
Screenshot of the current aircraft firmware version:
2021-8-23
krzysando Posted at 8-23 21:25
Hi, can you activate the camera normally after you try to downgrade the firmware version?
2021-8-23
krzysando
DJI Gamora Posted at 8-23 22:44
Unfortunately not.
2021-8-23
krzysando
Upload from mobile device:
https://drive.google.com/drive/folders/1lWmqWT-A5i2j8WLYV6QR3U28K7bFeRBA?usp=sharing
2021-8-23
krzysando
And from DJI Assistant 2:
https://drive.google.com/drive/folders/1brwmqgGdc8JFiuL8tJZ65qeGONsHFR5_?usp=sharing
BR
2021-8-23
krzysando Posted at 8-23 23:29
Hi there. I have forwarded these information to the appropriate engineer, will look into it and help you get an update soon.
2021-8-25
krzysando
UPDATE:
The problem turns out to be more complex.
Today I visited a friend who has the Inspire 2, Matrice 210 V2 and X5S camera. It turns out that:
1. My X7 camera works fine on its M210 V2 and Inspire 2.
2. His X5S camera works fine on my Inspire 2.
It seems logical to think that the problem lies with the drone itself.
The question is, are you able to solve the problem remotely? If I don't get a reply in the next 15 hours, I won't waste my time anymore and send the drone back to the service center.
Another question: who will pay for renting a drone until my return from the service?
2021-8-25
We're so sorry to hear about your experience. If I were in your position, I would feel just as you do. Our engineers are currently rushing to locate the problem, but I have not received more information. Understand your request for urgent resolution, we suggest you contact our DJI support to start a case, send the machine back, and we will give you a solution. Apologize again for the inconvenience caused.
2021-8-25
