Motors rotate too fast (Naza M Lite)
3822 11 2014-11-17
C3tax
Hello.
my problem is that too quickly turn the motors on startup frequent.
I have already changed the Naza Lite software, the speed at all levels.
Unfortunately, without success.
I have a Hexacopter with Naza M Lite with GPS.
What struck me when I connect the battery for the first time, I then wait about 3 minutes, turn the engine too fast.
I disconnect the plug and then shut it again, turn the motors at the correct speed.
But that does not always work, sometimes I have to repeat 3x-4x.
Where is the problem?
PS: Sorry for my English, I speak German and have used Google for translation.
With best regards
Stefan
2014-11-17
Tahoe_Ed
Flight distance : 2605 ft
Stefan,
What escs, motors and RC are you using?  That will help us.
2014-11-18
C3tax
hello,
I can not exactly say, I have bought a RTF Copter from RCMaster and do not give very much known.
I have a Flypro X600 (Link)
What I do know is there 1100KV 2212 engines are installed.
And the ESCs have 16A.
More RCMaster has not announced on demand.
RCMaster manifests itself not to do so.
I hope you can help me.
With best regards
Stefan
2014-11-18
Blade_Strike
Flight distance : 872694 ft
Maybe an esc calibration issue?
2014-11-18
DJI-Soarsky Pri
China
Dear C3tax
pls tried to connect the Naza M Lite assistant to adjust the parameter of Motor Idle Speed. Maybe it will helpful for you.
Best Refards,
DJI Innovations
2014-11-19
xswamix
Your motor KV is to high for NAZA firmware, it is expecting 900KV
2014-12-20
Blade_Strike
the firmware does not matter what kv motor is running. I have used NAZA with 400kv up to 2200kv
2014-12-20
xswamix
Blade_Strike Posted at 2014-12-21 05:37
That's o.k. if you know what you are doing and adjust props and battery voltages properly to maintain a balanced system, which is beyond the capability of the average end user.  If not, you are not operating in the center of the autopilot PID loops and have just become a test pilot.  The aircraft will have narrower margins of safety, even if it appears to fly normally.
2014-12-20
Blade_Strike
This is so far off.. I will just agree to disagree and move on.. But I will give you a hint, this is why we can adjust the gains on any flight controller
2014-12-21
xswamix
O.K., but consider this - why do you have to change from NAZA to WOOKONG or A2 when you get beyond a certain size??
2014-12-28
freddiebd
Flight distance : 1891184 ft
^ Apparently the IMU in Naza is not as accurate and sensitive compared to the separate IMU's of the WKM and A2.
2015-1-3
Blade_Strike
Exactly, you can still do it though. I have had naza on 1000's to 200 size quads.
2015-1-3
