M2EA problem with thermal image burn
2473 9 2021-11-15
DMCmaps
Does anyone know the cause/solution for thermal imprints like these? (The heat signature of the tree seems to have temporarily burned into the thermal images leaving its imprint even when a body is blocking the tree from the view of the thermal lens). The imprint eventually fades - only to get replaced by heat signatures of the objects in the new FOV... rendering data collection near impossible.
2021-11-15
fansa82ef67b
Flight distance : 4752352 ft
Colombia
Do FCC, this maybe refresh the sensor
2021-11-24
djiuser_R6fsB8QkmwJF
Hey.
I think I have the same problem. Did you find a solution for?
I hope it would help me
2022-5-20
NlsHmm
fansa82ef67b Posted at 2021-11-24 19:04
After I Refresh the Sensor with FCC a new image is still burned. Any further solution?
2022-5-21
NlsHmm
After I refresh with FCC a new image is burned. Any further solution?
2022-5-21
NlsHmm
2022-5-21
SimonID
I've seen this effect on other FLIR thermal cameras (Lepton 3.5) where the shutter for calibration was stuck. May be a physical thing to be checked by DJI service.
2022-5-27
NlsHmm
SimonID Posted at 5-27 01:08
Thanks for your help. I think there is no other way then sending the drone to DJI.
2022-5-27
wicom.pqgmail.com
Flight distance : 2392844 ft
Peru
I have the same problem, any Solution please?
Write here : wicom.pq@gmail.com
2023-9-15
Flying Scorpion
Flight distance : 724288 ft
Réunion
wicom.pqgmail.com Posted at 9-15 21:34
Send it back to DJI. You're sensor is burnt.
2023-9-28
