jerryway
Flight distance : 4031483 ft
Nicodema Posted at 11-29 09:33
Huh? I'm not sure I understand you. I assumed the OP was wanting an adapter so that he could use a Mavic 3 battery AS a power bank. Sounds like you are talking about using a power bank AS a mavic 3 battery, which would seem unworkable, or charging a M3 battery from a power bank, which sounds perfectly feasible with just the 3 battery charging hub, which is available from DJI.
I'm now not sure which of us has misunderstood.
I am talking about a USB-C to Mavic 3 battery port adaptor, which allows user to connect Mavic 3 batteries directly with power bank or car charger with a USB-C port. Mavic 3 battery supports USB-PD protocol up to 65W, or PPS fast charging protocol up to 88W. Right now if you want to charge the battery, you have to put it in the drone, or in the battery hub. With battery port adaptor, it should be possible to charge one or multiple Mavic 3 batteries at the same time, with a large capacity (e.g., 26800mah) power bank with one or multiple USB-C port. Right now if I want to do that I have to purchase multiple battery charging hub, not only they are big and balky, they are also an unnecessary waste of resource.
The adaptor should look like this one (for Mavic 2 Pro):
