Is there a flight mode to take 360 degree video at a spot?
2784 5 2022-4-6
Drone AV
Flight distance : 246650 ft
Dear Forum,
I would like to take a 360 degree video at a spot?  How can I do that smoothly at a preset speed?
For now, after airborne the drone at the position I want, then I turn on the video capture, then the push the LEFT Joystick Left or Right to spin the Gimbal.  I find it is very hard to get a smooth footage by manually controlling the LEFT Joystick.    Is there a flight mode that can be used to do this?
I have tried the Point Of Interest intelligent flight mode (POI), I can point the gimbal outwards to take a 360 degree video of the surroundings.  I can adjust the speed of the circulation.  But it requires to set up a radius and the radius must be larger than 16 feet.  But for my purpose, I want to have a radius of 0, and be able to control the circulation to very slow and smooth.   May I ask how can I do that ?
Sam.
2022-4-6
Wilson 000
Hello, friend~
If you want to get a smooth picture/video, turn down the gear, take a small number of rods, slow down.
Hope my answer can help you~
2022-4-7
The FPV drone is really not designed for photos/video,   youre probably better off with something supported by Litchi like a Mavic or Mini and then you can create a mission to do this.
2022-4-7
Cetacean
Flight distance : 2528264 ft
Aloha Sam,
     Good thinking with the POI!  But try shooting across the radius instead of out from the radius.   The speed slider then lets you slow way down.
      Hope this helps!  Take care and be safe!
Aloha and Drone On!
2022-4-7
Drone AV
I try to avoid using POI, because it takes a few steps to setup, in addition to the need of setting up a radius > 16 ft.
2022-4-7
Blériot53
Flight distance : 6260935 ft
Have a look at this video - see if any of the tips help you:
2022-4-12
