DJI Phantom 2 Vision Hidden Network
2556 7 2022-4-22
JohnInHawaii
I am trying to get an old Phantom 2 Vision up and running again and I cannot see the wifi network to connect to. It should be Phantom_xxxx but it isn't there. I used a spectrum analyzer and found the hidden network with SSID listed as [HIDDEN] on 60:60:xx:xx:xx:xx. I cannot connect to this with my iphone. I don't know what to put as the SSID. Literally putting in [HIDDEN] on 60:60:xx:xx:xx:xx doesn't work, nor does the MAC address, nor '[HIDDEN]". Anyone have any ideas?
2022-4-22
Mark The Droner
Flight distance : 2917 ft
Have you read the manual?
There are two Phantom wifi signals that are being broadcast during the wifi connection process.  You say the wifi network to connect to is not visible on your mobile device wifi list.  Is the range extender turned on?  Does it boot up correctly?  Did you push in the binding button on the range extender with a paper clip and then wait 45 secs?  The wifi signal coming from the range extender should be visible on the mobile device wifi list provided the wifi coming from the P2V is working.  When you see Phantom xxxx listed on your mobile device wifi list, that's the one coming from the range extender.  Connect to it.  The one coming from the P2V is deliberately hidden from you and not seen on your list of wifi signals because you aren't supposed to connect to it.  The range extender can see it and will connect to it.  The range extender is a bridge between your mobile device and the P2V.  If you see it with your wifi analyzer, that's good news because you now know the wifi is working.  But you should see BOTH signals with your wifi analyzer app.  Write down the MAC address for that hidden wifi signal - you will need it to bind the FPV wifi connection using the P2V flight app when prompted.
Here is a good demonstraton of how to bind.  The procedure is the same for both the P2V and P2V+.
Let us know how things go.
Good luck
2022-4-23
JohnInHawaii
Mark The Droner Posted at 4-23 03:37
Sadly, I only see the hidden signal and not the regular Phantom_XXXXX one. I think the wifi module must have gone bad in the years I wasn't using it. I had had it replaced once during its lifetime. Perhaps something about draining the battery down over the years killed it. Oh well. I have this,, a P3, a P4, and a mini, so I was thinking about selling both the Vision and the P3 on eBay or something, but that may make it a bit more difficult... thank you so much for all your help!
2022-4-23
JetSam
Flight distance : 3462946 ft
have you tried another Mobile Device?
2022-4-24
Mark The Droner
I would not give up on it quite yet.  If the range extender (RE) is bad, you can replace it pretty easily and cheaply.
2022-4-24
JohnInHawaii
JetSam Posted at 4-24 01:48
Yes. I tried both my computer and phone. I could see the hidden network from the Phantom, but not the extender's.
2022-4-25
JohnInHawaii
Mark The Droner Posted at 4-24 02:44
True, however, I am looking to sell it on ebay and may not be able to get anything for it. $25 for an extender on an object that may not net $100 may not be worth it Thank you for your help, though!
2022-4-25
Mark The Droner
Okay.  Consider you can still fly around and take video with it provided nothing else is wrong with it.  Good luck
2022-4-26
