ESC status error / phantom 3 advanced
34321 459 2020-5-20
PatOdl Posted at 5-3 11:06
I have an Phantom 3 Advanced with same ESC error message, could you send me the fix?
Hi, PatOdl. I have sent the link to you via PM, please check it.
2022-5-8
KargAdor Posted at 5-4 21:45
I am having the same issue - can you also send me the link on how to fix the issue on my drone - Phantom 3 Pro.
Thanks.
Hi, KargAdor. I have sent the link to you via PM, please check it.
2022-5-8
Hi, there. I have sent the firmware to you via PM, please check it. You can try it to check if the problem persists. Thanks.
2022-5-8
djiuser_epSqbdw5MIdw
Colombia
I am having the same issue - can you also send me the link on how to fix the issue on my phantome 3 professional. Thanks.
2022-5-11
ro_flyer
Flight distance : 7557283 ft
Can you check actual the RC battery voltage, in the Go app?
2022-5-12
110WestCape
Same problem here. Phantom 3 Pro. Appreciate the solution please.
2022-5-26
djiuser_epSqbdw5MIdw Posted at 5-11 03:35
2022-5-28
110WestCape Posted at 5-26 05:49
2022-5-28
djiuser_b62PfdPgO8Nh
I too have the same esc error after my phantom 3 pro sat for awhile, upgraded firmware without success.  Please send link to updated firmware fix!
2022-5-28
Turbonator
Flight distance : 13425 ft
I have the same problem with my Phantom 3 Advanced. It worked fine the last time I used it, no crash. THen it sat unused for the past 2 years, and now I am getting an ESC status error and it refuses to start the motors up.
2022-5-30
Turbonator Posted at 5-30 09:08
Is anyone monitoring this thread this week?  Please send updated firmware link for these issues!
2022-6-6
wingfoiler
djiuser_b62PfdPgO8Nh Posted at 6-6 08:38
a link would be appreciated.
2022-6-6
NateDouglas97
Flight distance : 1696060 ft
P3A having the ESC Error as well. Can I get a PM with the link please.
Thanks in "Advance"
(Sorry for the pun)
2022-6-7
djiuser_EAP4BMVuqNW2
Am having the same issue. Please let me know how I can fix this issue.  Warning ESC Status Error. Restarted several times and says to contact support.
2022-6-7
2022-6-7
DJI Natalia Posted at 2021-1-10 03:07
Hi there, I have replied to your PM, please check it, thanks.
I have same issue with Phantom 3 Pro, please help.
2022-6-8
DJI Natalia
djiuser_EAP4BMVuqNW2 Posted at 6-8 10:00
2022-6-8
DJI Natalia
NateDouglas97 Posted at 6-7 01:01
Thanks in "Advance"
2022-6-8
DJI Natalia
2022-6-8
DJI Natalia
djiuser_b62PfdPgO8Nh Posted at 5-28 09:46
2022-6-8
DJI Natalia
wingfoiler Posted at 6-6 19:30
2022-6-8
fans09590221
Hi Natalia, I am also having the same ESC Status error message, would hugely appreciate if you could send me the updated firmware?
Thanks so much
2022-6-12
freewilly134
Flight distance : 42008 ft
I have also a DJI Phantom 3 advanced and with the same problem. Can you send me also
the firmware by PM...Thnank you very much
Regards
Rob
2022-6-14
djiuser_U9grhjnKmqPK
DJI Natalia Posted at 2020-12-24 20:30
Hi there, I have sent you a PM, please check it, thanks.
Hi Natalia,
My Phantom 4 is repeatedly showing the ESC status error.
It did crash back in December and I haven’t flown it since, but was hoping to try and get it back in the air.
I’m not sure if it’s an issue with software or hardware, can you help?
2022-6-14
DJI Natalia
fans09590221 Posted at 6-12 02:57
Thanks so much
2022-6-14
DJI Natalia
freewilly134 Posted at 6-14 02:57
Regards
2022-6-14
DJI Natalia
djiuser_U9grhjnKmqPK Posted at 6-14 05:59
Hi Natalia,
Hello, there. We will check your problem and send you a PM as soon as possible.
2022-6-14
djiuser_VtILZqhFEmeW
My P3 Advance has set for a while now I am getting a esc warning. I assume I need new firmware???? Any help is appreciated
2022-6-17
djiuser_vKG4wSkj1yvJ
I have a Phamtom 3 Professional and am having the same issue with the "ESC Status Error" message when trying to start the engines. Please can you PM me any firm ware that might help the issue. Thanks
2022-6-26
djiuser_WbLth5iUt9BT
Mongolia
DJI Natalia Posted at 2020-5-25 02:51
Hi there, I have sent you a PM, kindly please check it, thanks.
phantom3 professional esc status error. hi. what can i do?  it is not crash
2022-6-27
DJI Natalia
djiuser_WbLth5iUt9BT Posted at 6-27 10:52
2022-6-27
djiuser_hwI3oTZ4odeh
I am having the same problem. The Phantom 3 Advanced has not flown for over a year. Now I get the ESC Status Error. The drone has not crashed. What can I do?
2022-6-29
BWill
Phantom 3 Pro has been sitting for a long time.  Getting same ESC Error.  Can I get link to firmware?
2022-6-29
DJI Natalia
BWill Posted at 6-29 11:13
2022-6-29
DJI Natalia
djiuser_hwI3oTZ4odeh Posted at 6-29 09:09
2022-6-29
GEOMATICH
my P3A suddenly started giving esc status error, please help me
2022-7-1
Flyinhigh602
Hey there, I’m having the same issue with my p3a. Could you possibly help me out as well? Thanks!
2022-7-5
DJI Natalia
GEOMATICH Posted at 7-1 00:43
2022-7-6
DJI Natalia
Flyinhigh602 Posted at 7-5 23:40
2022-7-6
ShewyD
Hi I am having the same issue, can you please also send me the link for the firmware to fix the issue on my Phantom 3 Pro.
2022-7-9
