[RCG]Balthazar
Flight distance : 475371 ft
Ok panic has settled down, frustration is gone and I apologize
for getting mad at all the newbie links I'm fed in here. (I know youre trying to help)
Who knows, maybe I am a newbie at least when it comes to the Phantom 3 Pro.
I have tried my best to figure out what happened and spent countless hr's fiddling
with my logs and learning as much as possible about the tools aviable to analyze them.
Editing in my findings so far to collect it in one topic.
Click here to download The Log
Click here to open a Dropbox folder with all the relevant files.
Click here to see the flight on Flytrex.
Click here to see the flight on healtydrones
The DJI GO App displays the following data:
Flight Total Time 00 Minutes 51 Seconds
Traveled Distance 231,3 Meters
Max Height 41.7 Meters
The graph used to monitor status during flight displays
Height 41,0 Meters
Distance 199,5 Meters
Horizontal Speed 11,9 Meters per Second
Vertical Speed 12,7 Meters per Second
Remaining battery 51%
Mode Landing
Under the progress bar there were a warning
Critically low voltage, the aircraft will land now
If it kept flying along this trajectory for the remaining 51% battery it probably ended up somewhere in The Norwegian Sea.
The DJI Go Flight Log Player nor Flytrex displays the temperature data so for that we need to chack the log on healtydrones.
Last flight was well within the warranted 0-40c range.
If we look at all the flights on this battery we can see that it has never been used below 10c.
Kind of looks like the built-in balance charger does not allways balance the battery.
In addition the deviations varies between cell 1 and cell 4, at times even within the same flight!
So again, firmware, sensor or battery problem?
