P4v2 Gimbal position
507 3 2023-1-23
djiuser_vnwDu0HRlnh5
Does the gimbal typicall face down when not powered on?
2023-1-23
DJI Wanda
Hello, there. May we know if the gimbal works properly after you turn on the aircraft?
2023-1-24
DJI Wanda Posted at 1-24 01:51
Yes, it seems to work fine once powered on.
2023-1-24
DJI Wanda
djiuser_vnwDu0HRlnh5 Posted at 1-24 04:46
If the gimbal can be used normally and there is no error message after self-calibration, then it is normal.
You may check whether you can rotate the gimbal freely when you turn the device off.
Provided that the aircraft works properly, you can feel free to use it.
2023-1-24
