djiuser_ROzUChCksw2L
DJI Tony Posted at 2-14 22:00
Hi there. Apologies for the delayed update. Here are some recommended troubleshooting steps you may perform:
1. Remove the SD card from the aircraft if there is any.
2. Reset the remote controller. While powered off, press and hold the C1+C2+photograph button, and then press the power button to turn on the remote control, and you can see the green light on the remote control. Once done, connect to the app and upgrade in the module self-test. Please check if it can be recognized afterward.
1, OK did it though it's RC issue not drone.
2, RC enters a state that 1st LED is white, with 2 short beeps. In this mode, DJI Go 4 refuses to connect and DJI Go recognizes it as Inspire 1.
I've tried C1+C2+ISO wheel, recording button, pause button, none enters expected recovery mode. Sometime after many restarts RC is recoginized as Phantom 4 (non-pro) and 3 bars allows me to refresh. After I tried and restarted RC, nothing changed.
3, DJI Assistant 2 for Phantom doesn't support RC. Even for another working GL300F.
4, didn't work.
BTW, I tried another working GL300F, it still shows GL300B in MSDK sample program. Except that it didn't make MSDK crash. |
