skinleverton
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
I ordered on 13th Nov and got it on 7th January. What you will see and feel is every penny(cent) you paid, it is so so well made, absolutely solid(unless some screws are loose). I'm so impressed and happy to have made the jump from Phantom all be it a little nervous of crashing, loosing it.
Hardest part of update was reading the small serial no on the back, didn't like it a few times and even said not recognised but started download. Drop the file on the sd card(not in a folder) and off it goes, it runs the update on the iPad screen. It did say a txt file would be on the sd with complete on it, mine said cancelled but screen clearly said latest update, use a usb stick with sd card in or load update to stick for controller, beeps all the time and you get a green light. Easy. If your lucky enough to have more than one battery it has to be updated as well. I think it will detect battery.
One thing I must say is get good at what to do and in what order, what i mean is turn on, lift from carry position, turn off, fit camera, connect lead to screen/control unit, I did it a few times, set it all up and was stumped as to why I had no signal and picture, well I'd not fitted the cable. That took a few on offs and checks before I noticed...
Hope you're waiting ends soon, Enjoy. |
