DJI Natalia
Marco899 Posted at 11-12 11:10
Today the first flight after the update and am not really happy. Upside down drone doesn't stop the motors anymore, the drone drifts a bit and panos get worse stiched. And that with windless weather.
Hi, there.
We are sorry for the inconvenience caused.
May we know if your problem is resolved now?
If not, could you please check the following details and keep us updated?
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range.
3. Please move to another flight environment to test.
4. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
5. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
Should you have any further questions, please feel free to let us know.
