arm repair?
2718 14 2023-5-3
Cavids
just noticed that one arm on my mini 3 pro, is difficult to rotate out and when in the closed position there is some play, it is not the arm that opens straight out it is the one that rotates down.  once open it seems fine.   Has anyone sent one like this in for repair, any idea how much it ended up costing to repair it and how long it took?
2023-5-3
Hi, Cavids. Thank you for reaching out. Can you please provide us with a video of the issue for us to confirm if it needs to be sent in for repair? Thank you.
2023-5-3
I had a loose arm and they charged me £40 to repair it.
2023-5-4
Burt37
Flight distance : 4009 ft
When they are in the folded position I have a little play as well. But as long they don't move when in the open position, I'm not sure what you are trying to achieve here.. Are you worried that it will eventually fell off?
If it is fine when open, like you said, than you have no issues...
2023-5-4
Burt37
DAFlys Posted at 5-4 00:20
Bloody hell... That's an arm and a leg....
Sorry couldn't resist...
2023-5-4
Burt37 Posted at 5-4 00:30
But they dont repair them, they just send you a new drone.
2023-5-4
Burt37
DAFlys Posted at 5-4 00:32
I believe you.. In China probably, that's all they are worth it to make...
2023-5-4
Cavids
yes when open there is no wiggle, but opening the one arm is not smooth at all, I have to kind of guide it to get it open, the other side just opens correctly
2023-5-4
Burt37
Cavids Posted at 5-4 10:39
Then if that's the case, your option was on post n.2..  Send dji a video and see what they think...
2023-5-5
Sean-bumble-bee
Flight distance : 15997 ft
I'd suggest shooting the video then adding it to youtube and posting a link here.
How old is the drone?
Have you crashed or dropped it?
2023-5-5
Burt37
There are other options as well...
https://www.ebay.com.au/itm/145055145373
2023-5-5
djiuser_E61FCQDaYZBl
Flight distance : 232720 ft
is it like something caught in the arm or a loose screw or something along thoes lines?
2023-5-5
Sean-bumble-bee
Front or rear arm?
2023-5-5
Burt37
Rotate down... Front
2023-5-5
Sean-bumble-bee
In that case, there are two screws that hold the arm onto its pivot, remove those and the arm can be pulled slightly clear of the pivot and you might get room enough to see if the 3 screws that clamp the actual pivot to the drone's shell are in place and tight.
A concern would be whether or not a screw has been pulled out, note PULLED OUT, of the shell or if one of the screw holes has cracked. or if the shell itself has cracked.
Any of those would really require a shell replacement.
However if DJI can detect that an arm has been removed and replaced then the warranty may be voided.
If one screw has, for whatever reason, come loose and it is not fixed I would suggest that it is only a matter of time before problems arise with the other two screws and or the drone's shell
2023-5-5
