RC PRO Antenna will not stay in position
4117 55 2023-7-21
mpoczynek
Flight distance : 11693 ft
My left antenna picks where it wants to be.  It does not stay verticle or in any other position.  Help! Video attached.
2023-7-21
Sean-bumble-bee
Flight distance : 15997 ft
Have you dropped the controller or has it/the-antenna been subjected to force e.g. squashed in a bag etc.?
If the RC Pro antennae are fitted in the same way as those of the P3 controller, the internal 'legs'/catches of the antennae inside the controller are a 'stiff' sliding/rotating fit in the bore of a short 'tube' that is part of the controller's shell. If a "leg" or the "tube" has been cracked then that might lead to what you see.  With that in mind and if confirmed by someone else and if the controller is still under warranty it might be an idea to return the controller for assssment/repair as it might be considered a warranty matter and thus FOC. I was going to suggest a DIY examination of the controller if it is out of warranty but I can not find any dismantling videos for the RC Pro.
If you end up returning it just be sure to remove and memory cards and, if important to you, back up the flight records folder to computer etc..
2023-7-21
mpoczynek
Sean-bumble-bee Posted at 7-21 03:10
Interesting.  Thank you.  The controller has not been dropped.  This problem just "appeared" yesterday.  Thanks for your help, regardless.  Cheers.
2023-7-21
Sean-bumble-bee
I added some afterthoughts to the other post.
2023-7-21
mpoczynek
Sean-bumble-bee Posted at 7-21 03:23
I added some afterthought to the other post.
Thank you.  I really hate to send it back to DJI, but it may be the only option.  This is the second remote with issues and I also had a bad Samsung 256GB card.
2023-7-21
Sean-bumble-bee
Hopefully you discovered the card fault in testing before you used it.
2023-7-21
mpoczynek
Sean-bumble-bee Posted at 7-21 03:33
Not that lucky.  Brought it home, and it was DEAD!
2023-7-21
Sean-bumble-bee
mpoczynek Posted at 7-21 03:34
Ah, I run h2testw on all new to me cards irrespective of where they are from. Mind you 256G would probably take my computer about 6 hours for the combined write and read, it is a 'bit' of a slow test though you can I think break it down into separate write and then subsequent read test. I have not experimented to see if the write test can be sub divided. It writes sequentially named files to the available free space on the card and two or more partial writes might create multiple #1, #2 etc. files, which might confuse the read test, .......  interesting question.
2023-7-21
mpoczynek
Sean-bumble-bee Posted at 7-21 05:32
Thank you.  Good advice.  Have a nice day!
2023-7-21
Hi there. Thank you for reaching out and we're sorry for the unpleasant experienced. You may consider sending the RC in for a proper diagnosis. You may submit a ticket case at https://repair.dji.com/repair/index . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support.
2023-7-21
TonyPHX
Flight distance : 11229610 ft
The RC Pro controller I got with my Mavic 3 Pro Cine had exact same problem right out of the box..   I sent it in, they fixed it and returned it. It was a spring in there.
2023-7-22
mpoczynek
DJI Paladin Posted at 7-21 17:52
Thank you.  I was hoping I did not have to do this.  This is the third return with the same Mavic 3 Pro Order.  A bad battery in the original remote, a bad memory card, and now this.
2023-7-22
mpoczynek
TonyPHX Posted at 7-22 02:26
Thank you.  I will do.  Have a nice day!
2023-7-22
Sean-bumble-bee
Do you by any chance have a photo of the spring etc.? I like to see how things are put together.
2023-7-22
mpoczynek Posted at 7-22 02:50
Our sincere apologies for the issue. We will surely handle this issue on your controller properly at our repair facility once we receive the unit.  Thank you for your understanding and support.
2023-7-23
mpoczynek
DJI Paladin Posted at 7-23 06:09
Thank you.  Now onto the third controller. I hope that the design will improve based on these returns.  Thanks for the message and have a great day!
2023-7-23
TonyPHX
Sean-bumble-bee Posted at 7-22 11:59
I do have a couple of extra new left and right antennas I ordered from Cloud City Drones.  When I find where I stored them, I'll take a picture for you.
2023-7-23
Sean-bumble-bee
TonyPHX Posted at 7-23 11:23
Are you sure that "stored" is the correct terminology? I use "safe place"
2023-7-23
mpoczynek Posted at 7-23 06:10
You are most welcome. Wish you have a wonderful day too, mpoczynek.
2023-7-24
mpoczynek
Thank you.  It is appreciated.
2023-7-24
mpoczynek
Can I send JUST the remote in, or do I need to send the entire kit?
2023-7-24
mpoczynek Posted at 7-24 05:05
Hi there. No need to send the entire kit. Sending just the RC Pro should be fine if it's just an issue with the antenna. Also, make sure to not send any 3rd-party accessories or devices (e.g. SD cards). Have a great day ahead.
2023-7-25
mpoczynek
DJI Tony Posted at 7-25 00:44
Thank you.  On its way today!  Cheers!
2023-7-25
mpoczynek Posted at 7-25 02:01
No problem. Awesome. Thank you for your valued support and have a great day ahead.
2023-7-25
mpoczynek
DJI Tony Posted at 7-25 02:03
Thank you.
2023-7-25
TonyPHX
I only sent in the RC PRo.  They turned it around the next day.  All in, it was not a bad experience.  These things happen in shipping.
2023-7-25
TonyPHX
Sean, I can't find my RC Pro spare parts.  If you check out Cloud City Drones they have RC Pro controller parts and can probably find the exact assembly with the spring.
2023-7-25
Sean-bumble-bee
Cheers Tony ..
2023-7-25
mpoczynek
TonyPHX Posted at 7-25 18:36
I just shipped it UPS yesterday.  We shall see.  THANKS!
2023-7-26
You are most welcome. Feel free to contact us if you have other inquiries. Have a good one!
2023-7-27
mpoczynek
DJI Paladin Posted at 7-27 05:59
Will do thanks.
2023-7-27
mpoczynek
UPDATE:  In a very timely fashion (my compliments to DJI), have diagnosed the problem as "parts with detailed cosmetic damage," as the picture shows, and my unit is on its way back to me.  Thanks, DJI.  If there is anything more, I will post here.
2023-7-29
mpoczynek Posted at 7-29 03:17
Awesome. I'm glad your concern was handled very well. We appreciate your feedback, mpoczynek. You can always contact us for DJI support at https://www.dji.com/ca/support?site=brandsite&from=nav. Have a great day ahead.
2023-7-29
mpoczynek
DJI Tony Posted at 7-29 03:38
Thank you.  Have a great day!
2023-7-29
Pedro Correa Photography
Just received the mavic pro 3 cine for Christmas today, and my right antenna is doing that. Haven't even turned on anything. But the right antenna just drops down to the folding position.
2023-12-25
Pedro Correa Photography Posted at 12-25 14:19
We apologize for any inconvenience caused. We kindly suggest sending the remote controller back for inspection. We assure you that we will provide you with comprehensive after-sales services. You can submit a repair request here: https://repair.dji.com/us/repair/index Thank you for your understanding and unwavering support.
2023-12-25
mpoczynek
DJI Tony Posted at 12-25 21:47
It's quite a disappointment.  I had to send my remote back three times from brand new for the following reasons:
- antenna sagging
- battery would not charge
- screen went blank and was not usable
Now all is good.  On to remote #4.
Good luck!
2023-12-26
mpoczynek Posted at 12-26 04:17
- antenna sagging
Sorry, you had to return the remote multiple times. Rest assured you can always reach us if you need further assistance. We appreciate your valued support.
2023-12-27
mpoczynek
DJI Tony Posted at 12-27 00:16
2023-12-27
mpoczynek Posted at 12-27 03:56
You are most welcome. You too have a great day ahead.
2023-12-30
