Lens flare
546 4 2023-10-25
826 Raw
Flight distance : 424104 ft
Does anyone else suffer from lense flaire with the 17 - 28 mm, even when using ND filters?
2023-10-25
Ford4D
Flight distance : 7608 ft
ND filters are meant to step down the light level entering the camera.
They aren't meant to deal with lens flare. There are other kinds of filters made for that (which you can put on the front of the lens).
2023-10-26
826 Raw
Ford4D Posted at 10-26 15:08
Just seen this. I disagree, flare should correctly be solved by having the right coatings on the internal lenses.
2023-11-8
Ford4D
826 Raw Posted at 11-8 01:17
I don't know how new you are to cinematography, but this just isn't what ND filters are meant for.
You can't "disagree" with that. It's just facts
Also, there are no cinema cameras out there with internal 'lenses'. You might be using the wrong word. Maybe you mean "filter".
In which case, it would be a different kind of filter from an ND filter. Because ND filters are NOT meant to remove flare.
It's just the basics of photography.
2023-11-22
826 Raw
Ford4D Posted at 11-22 06:03
The coatings on the lenses. The NDs are internal to this camera and could refract light. I am referring only to the lenses or ND coatings. I am not looking for a back-and-forth conversation with you.
2023-11-22
