DJI ASSISTANT 2 SENSOR CALIBRATION TROUBLE
5049 14 2023-1-21
djiuser_z9w4qN6SvQGV
Flight distance : 201220 ft
Recently got a warning on the DJIGO4 asking to recalibrate the back vision sensor.
Installed old DJI Assistant 2 V. 1.2.5.  I upgraded to the latest firmware W 01.00.0620, reset to factory settings. Try to calibrate but the calibration screen does not show up. After sometime the DJI Assistant ask to REBOOT THE AIRCRAFT. I do it, repeat all process and it get stuck in this step. Tried in a laptop and also in a desktop and it is not working.
What to do? Could you please give some advise?
2023-1-21
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please confirm if the aircraft experienced a hard landing? You may try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value ( usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200 ). I will post a tutorial video below for your reference. Please keep us posted. Thank you.
2023-1-21
MMori
No the drone never did a hard landing. It is not that often used.
I tried what the video showed, however the CALIBRATION PATTERN does not appear on the PC Screen.
Why the Assistant 2 does not reconize the drone and show up the calibration pattern?
What to do in this case?
2023-1-24
MMori Posted at 1-24 15:04
Thank you for your response and we're deeply sorry for the trouble that this has caused. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You may contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your kind and understanding.
2023-2-17
djiuser_KtWvhBIEjZPN
Zimbabwe
Hi
So I’ve been having a problem with my downward vision sensor. I’ve been trying to use the DJI assistant 2 but it doesn’t come with the calibration option and I don’t know why. If anyone has had the same problem please contact me. I’m using a DJI Mini 3
Kind regards.
2023-9-17
QuinnyE
Flight distance : 2021 ft
This is disgusting from DJI, I too have the same problem where I can't get the calibration prompt to go, my drone has never had a hard landing.
I feel DJI do this so you end up having to buy another drone.
Bunch of crooks
2023-11-11
QuinnyE Posted at 11-11 23:18
Hi, QuinnyE. Sorry about the experience. The Mini 3 does not support vision calibration using DJI Assistant 2 software. May I know what issue are you experiencing with your aircraft? We are more than glad to help.
2023-11-12
djiuser_KtWvhBIEjZPN Posted at 9-17 00:34
Hi
Hi there. Sorry about the inconvenience. The vision sensor calibration for Mini 3 using the DJI Assistant 2 is not supported. May I know what error message are you getting from your remote? Thank you for your patience.
2023-11-12
terrinecold
I have the same problem as the opening post with my Mavic air (original). DJIGo4 asked to recalibrate the back vision sensor.  I can connect to the dji assistant 2 version 1.2.5 but when I try to calibrate I do not see any patterns.
Note that the software didn't seem to correctly detect my screen and asked for the size in inches which I supplied (27)
1-9 07:02
terrinecold Posted at 1-9 07:02
Hi, terrinecold. Sorry about the trouble. Please try closing the Assistant 2 software and then open and edit the set_screen_size.txt file in the DJIEngin catalog. Edit “unknown” + “Real screen size” and then Save. Note: There must be a space between the “unknown” and formal size. Re-launch the DJI Assistant 2 for calibration. If the issue persists, it means the screen cannot be supported. We recommend trying another screen or computer to conduct vision sensor calibration. We appreciate your patience.
1-9 22:08
fansac563f15
Hello there, I have been trying to calibrate the vision system of my mavic pro 2 as it was impossible to fly ( there was a sign telling me to do it using DJI assistant 2, once I’m ready to start the calibration I got stuck ( can not detect screen size) I here attach photos.
I really need to get this sorted I can’t use my drone anymore, I’m very disappointed with DJI as I’ve spent a lot of money in my drone when they first released it. I hope your soon answer.
5-5 07:53
fansac563f15
I here attached the photos of the issue trying to calibrate the sensors
5-5 17:07
fansac563f15 Posted at 5-5 07:53
Hi there. Thank you for reaching out. Kindly follow the steps I provided in post #2 on this thread to see if the issue persists. If you still experience the issue when calibrating via DJI Assistant 2, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support.
5-6 01:11
djiuser_Z93KCsXx8GuE
Hi there I just purchased a Mini4 pro from Australia & then shifted to India used my drone for 2-3 times no hard landing done. One day I turned it on suddenly visions sensors stopped working it started showing no upward/downword/front/back etc.available. When I tried calibrating it on Assistant 2 app, there was no option for calibration. Please resolve my issue as my drone is new and I never faced such problem with my previous drone. If the problem is not solved it is as good as dust.
Please help ASAP as I have a few projects to shoot
5-19 06:38
djiuser_Z93KCsXx8GuE Posted at 5-19 06:38
Hi there. According to India Import Policy, Drones are 'prohibited' except for R&D and defense use. There are no DJI Authorized Retail Stores in India to sell drones. So we cannot provide aftersales services for you. Sorry for the inconvenience caused and your understanding is highly appreciated.
5-19 21:52
