djiuser_ZDta7Hvu8xrd Posted at 10-18 16:49
Yes, I can confirm the flight speed issue is happening on any flight I use the Matrice 300 since the latest firmware update. I've only addressed this issue on this forum and don't have a reference number.
Hi there, I am sorry for the belated reply.
1. For the flight speed, kindly confirm which of the following situations it belongs to:
a. When planning the route, when setting the flight speed, the speed cannot be set greater than 18 miles per hour. If this is the case, the flight speed is calculated based on the flight altitude and course overlap.
In order to ensure that no shots are missed, the maximum speed will be limited. Flight speed, if the customer needs greater speed, the flight altitude can be increased or the course overlap can be reduced (reducing the overlap will affect the later reconstruction effect);
b. If you referred to the speed planned by the APP as greater than 18 miles per hour, but the actual flight speed is much less than this, kindly provide the corresponding route tasks, flight control data, specific flight time, and the firmware version for further analysis.
Regarding the camera issue, kindly confirm the gimbal angle you set for the flight. If it deviates a lot, please try to calibrate the gimbal and refresh the firmware, if the issue is the same, you may send the unit back to us for further check. Thank you. |
