How to change fps in Hyperlapse?
762 6 2023-12-11
Finnborg-Braga
Flight distance : 258478 ft
The Action 4 seems to have a fixed fps of 29.97 when in hyperlapse.
Is there a way to change the (output) fps within the camera settings?
2023-12-11
osmonauta
Hungary
nope
too short
2023-12-12
Hi. I hope you're doing well today. Regretfully, it is not possible to change the fps when  Hyperlapse. I'll forward this as feedback to the related team. We appreciate your patience and valued support.
2023-12-13
Finnborg-Braga
29.97 fps is a NTSC framerate, and 'alien' in Europe and many other places in the world. I would suggest that being able to change the fps to 25 is a minimum requirement to make Hyperlapse usable outside North America.
I would also suggest that higher frame rates (50 / 60 fps) would be a good move. Enabling Horizontal Balance would also be good.
As it is at the moment, Hyperlapse is pretty useless to me. I am recording 4-8 hour hikes, and condensing the footage to 5-10 minutes. I have experimented with Hyperlapse but had to go back to 'standard' video and speed up the footage in post - but that means very large 'raw' video files to store.
2023-12-13
osmonauta
Hungary
30fps is “alien” in the EU? I do all my recordings in 30fps, including hyperlapse and timelapse. Never had an issue. Are you still using tube television?
2023-12-13
Fishycomics
maybe they can pass  it on.  DJI has more or less allowed all FPS in the Video mode, but otherwise they  limited the rest,
2023-12-13
insert.coin
osmonauta Posted at 2023-12-13 03:44
How do you deal with a certain type of light flicker when shooting at 30/60 fps in the EU?  These lights seem to be quite common among businesses as I move pass them, their lights just produce an annoying flicker when I shoot 30/60 fps.
30 fps probably might be ok with hyper lapse if the clip is used on it's own but if you had to blend the footage with a timeline that is 25fps for the sake of PAL and reducing flicker on certain lights, a 30fps (or rather 29.97 fps) clip in a 25fps timeline is not exactly a pleasant experience.
4-27 13:40
