Problem DJI Transmission with Fujifilm XH2S
1685 6 2023-1-16
Shikijo
Flight distance : 3323150 ft
Hi, the DJI Transmission creating something weird on the Fujifilm XH2S when you plug the HDMI on the DSLR.
Video is here, and as you can see the HDMI input of the RX from the DJI Transmission sending bad command to the DSLR who creating bootloop. I figure it's because the HDMI sending 4.2.2. 10 bit to the HDMI.
Can you check that and fix it DJI ?
There is a video who showing the problem : https://youtube.com/shorts/2F-rhpiC5co?feature=share
2023-1-16
djiuser_1tWyYoiDMnEB
I have exactly the same problem with my Fuji XH2S too. No problem with my Blackmagic Pocket 6K, same with my Panasonic GH6, but impossible to connect my XH2S to the DJI Transmission. I don’t know if this is a problem of resolution, bitrare, sampling... but it would be nice if it were fixed quickly!
2023-1-17
Shikijo
The strange thing is the Fuji XH2S work well with the Raveneye unit... I think it's about the 4.2.2 output from the fuji.
2023-1-17
BackyardFilms
I went to the DJI Store, we tested with several cameras, everything works. But with the Fuji, it doesn’t work.
When you connect the Fuji to the DJI High Bright Monitor, it works, but when you connect it to the DJI Transmitter, nothing works. My screen still flashing.
Nobody seems to understand the problem, it makes no sense. So they paid me back and I’m waiting for Fuji or DJI to take over the problem and fix it in a future firmware update. In the meantime, there seems to be no solution.
2023-1-17
Shikijo
For me it's a small problem from the DJI Transmission TX who are sending the wrong value to the HDMI port to the Fuji XH2S.
When you try with raveneye or other screen, the DSLR will reboot when you remove the HDMI, surely for ground security or stuff like that.
I already figured some weird stuff about ground loop on the DJI Transmission on my previous test, DJI need to check that.
2023-1-17
djiuser_RSOVvw8Ul0FF
Same problem. Latest firmware on the X-H2s and the Transmission. One workaround I’ve found is to use a blackmagic sdi to hdmi converter. Definitely makes rigging harder and uglier but it works for now. Just wish DJI and/or Fuji would fix this crap. Unbelievable.
2023-12-30
Wilsonized
Same issue. Used a Ninja V to passthru HDMI to the Transmission.
1-15 15:55
