Not used in 3 years, now battery not turning on.
19649 36 2023-3-18
Pgaucher
Hi everyone,
I have not used my drone in 3 years and all 3 batteries do not turn on or even charge. I've tried charging them for 24 hours and even that doesn't work.  Are my batteries blown? Is there a trick to wake them up from their perpetual sleep mode?
Any advice appreciated.
Cheers
Patrice
2023-3-18
It's most likely that the batteries have died and you'll need a replacement.
2023-3-18
Sean-bumble-bee
Flight distance : 15997 ft
It is probable that there is 'chip' of some sort (gas gauge?) on the battery's contol board that switches to open circuit if the battery's voltage gets too low, as is likely to have happened in this instance.
Once that has happened it takes 'specialised' equipment and software to switch the chip back on. Besides the cells themselve are probably knackered.
2023-3-18
Hi, Patrice. Thank you for reaching out and we're sorry for the inconvenience. How did you charge the batteries? Were there any lights when you charged them?
2023-3-18
Pgaucher
DJI Gamora Posted at 3-18 19:03
Hi, no there are no lights at all on all 3 batteries. Even after connecting to the charger for hours.
Is it possible the charger itself is defective? The USB port doesnt generate any power so perhaps thats the issue?
2023-3-18
DJI Wanda
Pgaucher Posted at 3-18 19:28
You may change a charger or cable to test it again. If batteries do not respond after doing that. You are advised to change new batteries.
2023-3-19
33db
The batteries do have a chip in them, if the voltage drops to low the chip basically makes the battery unusable, I know from watching videos of people trying to replace cells in their Mavic batteries, they had to keep a constant source of power on the chip to keep it from shutting the battery down.
They still sell Mavic 2 batteries, and I wouldn't buy them from anyone else but DJI.
This is the downside of corporate drones, build your own and you can always get new batteries, you just won't have the DJI features.
2023-3-20
mAIRs
There is a way to wake them up, look up "waking up mavic 2 batteries" and " Mavic 2 Battery Won't Charge | Easy Fix" on youtube... I'll post another reply with a link, I'll seperate the replies because I dont know if the commies wont block a link.
2023-5-7
mAIRs
2023-5-7
mAIRs
another method
2023-5-7
alpha_dji20
Flight distance : 15341 ft
Bangladesh
I have not used my Mavic Pro in the last 1 year. Now Batteries are not charging but they are turning on and drone showing "Low Battery".
What can be the issue here?
Please help
2023-10-1
Sean-bumble-bee
Read the thread.
2023-10-1
alpha_dji20 Posted at 10-1 05:13
Hi there. Sorry about the inconvenience. Can you please try the steps below:
① Ensure that the charging temperature range for the intelligent flight battery is within the required range;
② Ensure that an official charging cable and power adapter are provided and that the external power supply is normal.
③ Check the battery LED status, comparing to the battery LED status to confirm if the battery protection information is triggered by abnormal charging.
④ If possible, please replace the battery to see if the charger is working normally.
⑤ Please replace the charger if possible.
Please keep me posted. Have a great day ahead.
2023-10-2
Burner61
Flight distance : 1053 ft
Hi All. I have a similar issue, have not used my Mavic Pro in years and am learning (the hard way) about batteries. One of my four batteries is just dead, but the other three light up, full green circle, for a few seconds then go out. I can't power the drone on using any of them, wondering if the brief green circle is a glimmer of hope. I've found plenty of info on flashing lights, but have yet to find anything about lights that come on then go off. Thanks in advance for any help or suggestions.
2023-12-20
Burner61 Posted at 12-20 08:49
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Please try to discharge the battery that experiences an issue until it goes to completely 0%. After that, recharge or leave the battery on the charger until it is fully charged then check if the issue persists. Please keep us posted.
2023-12-21
fans12231982
Ukraine
Good afternoon, dear forum users and administrators. i faced a similar problem as described in this thread. i haven't used Mavic Pro for 2 years, but now, fortunately, two lights on the battery are on and one is blinking. charging is also happening. But what should I do now to extend the life?  should I fully charge and discharge, or should I fully charge and let them automatically discharge to 40-60%? and what should I do with the remote controler, repeat the same steps? thanks for any help and have a nice day, gentlemen!
2023-12-25
Mobilehomer
Flight distance : 18150351 ft
fans12231982 Posted at 12-25 05:42
Charge them fully. If you are not going to fly shortly, let the intelligent part take over. If not using, charge them fully and let discharge by themselves every month or so.
2023-12-25
fans12231982
Ukraine
Mobilehomer Posted at 12-25 13:42
hi, thanks a lot! I'll do it right away!
but what should I do with the remote controler, repeat the same steps?
2023-12-25
fans12231982
Ukraine
And one more thing: does it matter where I store the batteries? usually 2 are stored in the case and one in the drone itself, is this safe enough, and will they be able to discharge at the same level on their own? is it better to store them in Mavic, or away from it?
huge thx!
2023-12-25
Mobilehomer
fans12231982 Posted at 12-25 21:53
The remote needs no special care, it's more like your cordless drill, always ready. The best thing you can do is to fly at least once a week.
2023-12-26
Mobilehomer
fans12231982 Posted at 12-25 22:00
huge thx!
I keep mine in the charging hub(turned off, of course) and zero issues in over two years.
2023-12-26
djiuser_EnmdEwH3ExWU
alpha_dji20 Posted at 2023-10-1 05:13
LE logiciel Killer et le P2112 ça ne fonctionne pas c'est ces salops de DJI qui ont programmé pour bloquer le rechargement cela s'appelle l'obsolescence programmée. Tous des voleurs.
DJI France c’est une bande de bon à rien !!!! ils connaissent ce blocage volontaire et cela les arranges bien pour se remplir les poches.
1-21 00:03
mAIRs Posted at 2023-5-7 07:18
https://www.youtube.com/watch?v=1OJBWYHWFmw&ab_channel=614Lyfe
3 heures de blabla pour rien comme tous les américains ou anglais, des nuls.
1-21 00:04
solsystem7gmail.com
Flight distance : 6550331 ft
There is something a little strange going on. I have my original Mavic 2 batteries, which hold a charge for months with no problem, but when I purchased another "newer" battery, if I don't keep an eye on it and it goes low, it will not allow me to charge it...I have purchased 2 "newer" batteries and it has happened to both of them....I have attempted to use the de-bugging board as mentioned on YouTube, but no luck...This has also happened to my Phantom 4. I purchased one of the "newer' batteries and the same thing happened...I hate to say it, but I think the "newer'  batteries may have some sort of kill switch built in for good or bad, but only one party benefits from this....
1-22 20:50
bjr981s
Flight distance : 139698 ft
DJI Smart batteries have a low discharge current from the smart battery electronics. The batteries run down to zero if left in storage. The recommendation from DJI is to charge them every 3 months if you intend to leave in storage. Sorry to say it but your batteries are now destroyed and the chemistry has broken down.
1-25 00:55
mAIRs
djiuser_EnmdEwH3ExWU Posted at 1-21 00:04
Maybe for a miserable cretin... so much trying to help a arrogant french wanker... won't do that mistake again...
1-28 02:03
djiuser_l4IIxmywGdBK
Apparently these batteries have a crazy fast self discharge rate, especially for Lithium Ion.  I too have not used my drone for 3 years, and guess what, exactly the same issue. If this is a known issue, why doesn't DJI take them back and refurbish them with updated electronics with a slower self discharge rate.  Replacing the three nearly new batteries is not a low cost thing. Ouch!  At least send us a credit of something.  Tell me the new batteries have a much slower self discharge rate (like 2% / month)?
2-15 18:46
djiuser_l4IIxmywGdBK Posted at 2-15 18:46
Hi there. Thank you for reaching out and we're deeply sorry for the trouble. Can you please confirm what specific DJI product are you using? Kindly try to leave the battery on the charger for approximately 2-3 hours or more for each and check if there are some changes. Please note that we can only consider a warranty repair/replacement for a product that is within the warranty period. We appreciate your understanding.
2-16 02:42
Bug99
DJI Paladin Posted at 2-16 02:42
The drone is a Platinum Pro M1X model. The three batteries are model no: FBI-3830mAh-11.4V  There is no activity on any of the three after 24hrs of charger connection.
I would assume that the warranty period is shorter than the self destruct period, or this would not be a problem?
2-16 09:36
Bug99 Posted at 2-16 09:36
Thank you for your response. Can you please provide us with the serial number of one of your batteries so we can check it here on our end? You may provide us with the information via PM. We will wait for your response.
2-18 02:59
Bug99
DJI Paladin Posted at 2-18 02:59
sent PM.
Didnt see how to send an image in the PM.  assumed that the QR code was the serial number?
Is it normal that i dont get email updates when posts are made to this thread in the forum
3-6 08:56
Bug99 Posted at 3-6 08:56
sent PM.
Hello there. Thank you for your response. The serial number is located below the QR code. In addition, you can enable the email notification under your profile. Please go to your profile and click the check box below your avatar and username, you may refer to the image below.
3-9 00:02
Bug99
DJI Paladin Posted at 3-9 00:02
Above is how the setting is, below is the only option.  The Subscribe sentence is correct language, so it makes no sense.  The language should be: Subscribe TO (not from) email notifications (which I have checked). The below “Undescribed” is not checked.  Why am I not receiving notifications?
3-13 06:39
Bug99 Posted at 3-13 06:39
Thank you for pointing this out. Kindly please put a check box on it so you'll get the notification via DJI Forum. If you still don't receive it, please let us know. Thank you.
3-13 23:31
fans11c2f93b
I am done with DJI. I'm sick of getting screwed over by their drone software problems and battery problems and all out complete inability to help. I get nowhere with DJI I have invested tens of thousands of dollars in their drones and batteries and it is a waste with no support I have wasted weeks of time trying to resolve and deal with DJI with no avail
4-6 08:43
fans11c2f93b Posted at 4-6 08:43
Hello there. Thank you for reaching out. This is not the experience we want you to have. Please tell us the full details of the issue that you experienced with your DJI product and we will surely provide you with an accurate resolution after we review the details. Rest assured that we're committed to providing the best experience for our users. Please keep us posted. Thank you for understanding.
4-7 20:09
SunshynFF
Flight distance : 30010 ft
djiuser_EnmdEwH3ExWU Posted at 1-21 00:03
Calmez-vous, nous ne sommes pas tous des perdants, tout comme je suis sûr que tous les Français ne sont pas des connards pompeux qui détestent les Américains... rire à haute voix emoji
Je ne vais pas prétendre que DJI n'est pas des salauds, mais ce n'est pas une obsolescence programmée, c'est qu'ils essaient de rendre les choses trop intelligentes et autosuffisantes, mais ils s'attendent à ce que nous payions le prix quand cette technologie a des problèmes. Il existe de nombreuses façons de redonner vie à la batterie, il y a une vidéo juste au dessus ici. Ou n'utilisez pas leurs piles. Sur mon ancien Mavic Pro 1, j'ai piraté le logiciel de l'ensemble du drone, restauré le micrologiciel à l'original, supprimé toutes les restrictions, y compris les avertissements de batterie, soudé quelques connecteurs XT60 à la carte et alimenté le tout avec des batteries RC Lipo ordinaires. Et ce n’était pas si difficile du tout. Je peux vous orienter dans la bonne direction si vous êtes intéressé.
5-8 13:55
