DJI Mic 2 transmitter not receiving audio from plugged lav
1100 9 1-23 10:11
djiuser_RDNzi98nK5Yc
Hi there,
I am trying to record via a Shure lav mic plugged into the transmitter, but the signal is dead as soon as the lav is plugged. The same lav works perfectly with the first version of the DJI Mic.
Is this a known issue?
Thanks,
J.
1-23 10:11
Natural Sounds and Sights
Have you tried a different lav mic? Ocasionally you can find different tolerances with the 3.5mm TRS plugs/sockets. Which Shure mic is this?
1-24 09:31
RobZilla
Flight distance : 1057844 ft
Agree on the tolerances of 3.5mm TRS plugs and sockets. It is odd that the lav mic worked on the original MIC but not working on the MIC 2 transmitter. Does this happen on the other transmitter if you have the combo, ie TX1 and TX2? Have you played with the plug insertion and see if it works by not plugging it in all the way or making sure its fully seated in the hole?
1-24 10:24
It is the Shure mvl lav. I found a fix: you need a trrs to TRS adapter. It wasn't needed for the first version of the Mic, which is very odd.
1-25 00:47
Hello, there. Thank you for sharing your query with us. Please allow us to check this matter with our relevant team. The latest information will be forwarded here.
1-25 03:05
Hi, there. Please know that we've sent you the latest feedback regarding this query. Kindly feel free to keep us posted.
1-26 23:51
Thanks, I've bought the adaptor and it now works as intended with the lavs I have.
1-27 02:48
djiuser_RDNzi98nK5Yc Posted at 1-27 02:48
Thank you for your update. We're glad to know that everything has been sorted out!
1-28 00:41
fansf4828f77
Flight distance : 807365 ft
Experiencing exactly the same thing. The irony is that I bought 2 Shure lavs, after my previous Senheiser that works perfectly with the Rode Wireless Go (the original) didn't work with the DJI Mic 1. After searching through a bunch of Lavs, I bought 2 Shure MVLs, only for them to stop working with the DJI Mic 2.
3-23 18:01
Djnumone
Yes, the lav will only work with the DJI Mic 1. I bought a DJI Mic 2 system and am using a Shure MVL lav. You will need a female Trrs  - male trs adapter and that should take care of the problem
4-20 12:21
