smart controller stuck in start up logo
6639 13 2020-11-3
Panha Rith
Cambodia
Hello dear, after i update firmware of  smart controller and i got a failure update, then my smart controller keep restarting and and stuck on start up logo, so what should i do to fix my smart controller to working normally. Althought i try to use c1+c2+shutter button for factory reset it can't help!!!!
2020-11-3
Marty Markoe
Flight distance : 15135 ft
Did you use the DJI GO app to update firmware? If yes, try updating using DJI Assistant 2 on a computer.  See:
https://www.dji.com/mobile/downloads/softwares/assistant-dji-2-for-mavic
2020-11-3
Hello Panha Rith, thank you for reaching us out and my apologies this has caused you. It is unfortunate to know that your Smart Controller is stuck in start up logo. Have you tried to update the firmware using the DJI Assistant 2. I would highly recommend you to update it using the DJI Assistant 2 to ensure that you have downloaded the complete firmware version. As per commented by "Marty Markoe" under reply #2. You can refer to the link provided to download the DJI Assistant 2. https://www.dji.com/smart-controller/downloads
Once you have downloaded it follow this steps below on how to update the firmware.
1. Make sure that the remote controller is powered off. and connect it to a computer using a USB 3.0, USB-C cable.
2. Power on the remote controller.
3. Launch DJI Assistant 2 and login your DJI account.
4. Click the Smart Controller icon and then Firmware update.
5. Select and confirm the firmware version you want to update.
DJI Assistant 2 will download and update the firmware automatically please do not turn it off or remove the USB cable while it is updating.
6. The remote controller will restart after update.
You can also refer to the video below on how to update the firmware using the DJI Assistant 2. Please jump to 0:36 to proceed with the tutorial using the Assistant 2.
Please keep me posted so that we can further assist you. Thank you.
2020-11-3
Panha Rith
Cambodia
Marty Markoe Posted at 11-3 05:46
yes before i used to update firmware that pop up on the dji smart controller's screen, but i got update failure after i power off and i power on, the result is my smart controller keep restarting and won't do anything else.
2020-11-3
Panha Rith
Cambodia
DJI Paladin Posted at 11-3 06:49
how could i connect my smart controller via pc even it keep restarting and it doesn't connect to my pc.
2020-11-3
Marty Markoe
Is the USB Cable attached when restarting. Your USB cable may be suspect. Try a different cable.
2020-11-4
Panha Rith Posted at 11-3 18:37
Hi Panha Rith, thank you for your response. I feel sorry to know that still your smart controller is keeps on restarting. Would you be able to try a different USB cable if you have an extra, also try to let it connected to the PC until it detects by the PC even if it continuously restarting. If the issue persist, please send an email to our Support team to further assist you. You can send an email here at support@dji.com or you can refer to this link: https://www.dji.com/support?site=brandsite&from=nav scroll down the page and select Email. I'm looking forward to resolve your issue. Thank you.
2020-11-4
fans2dff26cd
Flight distance : 813360 ft
Panha Rith Posted at 2020-11-3 18:37
Unfortunately am facing the same problem , did you solve yours ?
Tks
2023-10-30
fans2dff26cd
Marty Markoe Posted at 2020-11-3 05:46
Did you got it ??
2023-10-30
fans2dff26cd
DJI please help me to solve them soon as possible!
Tks
I work with this equipament , so , am spend money to do my jobs while my Smart Controller isn’t work.
Please check soon as possible !!!!
Tks so much !
2023-10-30
fans2dff26cd Posted at 10-30 20:54
Tks
Hi there. Have you already tried the suggestions from reply 3# by DJI Paladin? Thank you.
2023-10-30
ahmet_oztemiz
Turkey
same problem with new brand dji mini pro 4 and could not connect to mac computer!
2-5 04:19
ahmet_oztemiz Posted at 2-5 04:19
Hello, there. Sorry to hear about this situation. Would it be possible for you to provide a short video showing the problem? You may upload the video to Google Drive or Dropbox and provide the link here. I hope to hear from you soon.
2-6 02:13
drone_guru
Flight distance : 7309911 ft
Fiji
Same Problem here with DJI RC Pro Enterprise for mavic 3 enterprise, brand new controller worked for about 2 hours and after that the Controller restarted on its on and when in to Boot Loop, screen is showing DJI, goes blank and boots again with DJI showing on screen and boots again, on repeat.
Can not use the DJI Assistant 2 (Enterprise) as the controller reboots and the connection to the DJI Assistant is lost every time.
5-20 13:11
