MIC 2 with POCKET 3 RECORDING PROBLEM
592 5 2-11 21:55
MacHead
I own DJI Pocket 3 with one DJI Mic 2 that came with Creator's Pack. Last week, I took this set up to a quite important event. I took about 75 clips, ranging from 10 sec to 5 minutes. I always paired my Mic 2 with Pocket 3, got confirmatiion window saying my Mic is now connected, and I proceeded with shooting. I always turned my Pocket 3 off between clips. When ready to take another clip, I waited until I got Mic 2 confirmed connection, then proceeded with shooting another clip. Distance between Pocket 3 and Mic 2 during shooting did not exceed 20  feet, in a clear, open space, no walls, fences, doors, trees, or  landscaping.
When I got home, and downloaded my clips, there was a problem with Audio. Some clips had no audio, some clips started with audio, but after few seconds audio disappeared, and some clips had good audio clearly recorded through Mic 2. Overall, Audio recording was inconsistant, and all over the board
Furthermore, once I downloaded my clips, I got separate audio file under each clip. Clips with good recorded audio to the clip itself, still have Audio file under video clip. I don't recall setting up  Mic 2 to record copy of Audio, nor did I intended to do so. Is that normal ?
But not having consistant Audio recorded to the Video, or no audio at all, is the biggest problem. Not sure what went wrong. It was my understanding that once you pair Mic 2 with Pocket 3, and get confirmation of connection - that you are ready to go. That clearly was not the case. My confidence in DJI Mic2 is now seriously undermined
Anybody with similar problem? Any help would be highly appreciated
Thank you
2-11 21:55
Hello, there. Sorry for the inconvenience that it may cause you. May I confirm if you managed to update the firmware of your DJI Mic 2 or Pocket 3? Also, may I confirm if the separate files are .wav files? I hope to hear from you soon.
2-13 03:23
MacHead
Hello, thank you for getting back to me. I have FW 1.03.05.02.in Pocket 3. Not sure how to get FW info for Mic2 to confirm. Yes, the separate files are .wav (see visual). Thank you
2-14 10:46
MacHead
DJI Gamora Posted at 2-13 03:23
Found it ! .. the transmitter FW is 03.05.05.12
Thank you !
2-14 11:11
MacHead Posted at 2-14 11:11
Thank you !
Thank you for your update. We're glad to know that everything has been sorted. Cheers!
2-20 22:40
MacHead
Hello, please, don't give up on me LOL .... nothing has been solved, I just submitted to you FW numbers - as you requested. Problem still exists. Thank you
2-21 10:02
