Qu for DJI. Does the set RTH height influence the %age at which ....
242 3 2-11 07:08
Sean-bumble-bee
Flight distance : 15997 ft
low battery RTH in triggered?
E.g the drone is 500m away at a height of 25m, if the RTH height is set to 500m will low battery RTH be triggered earlier than if the RTH height is set to 30m ?
Yes, I know I could test it and I probably will (obviously I will NOT let the drone go up to 500m ), but I want to see what DJI say.
2-11 07:08
Hi there. Thank you for reaching out. We will coordinate this concern with our relevant team for further clarification. We will keep you posted.
2-12 01:16
Hi there. Thank you for patiently waiting. Yes, first the aircraft will automatically determine whether the current battery level is sufficient based on the aircraft position information (including the RTH process), if the aircraft is flying below 500m altitude, if low battery RTH is triggered, it will take more power for the battery since it will need to ascend to 500m first before returning to home. Hence triggering the RTH earlier than the 30m RTH altitude set. Hope this helps.
2-19 02:39
Sean-bumble-bee
Thanks Paladin
2-19 04:20
