Using the Action 2 magnetic lanyard with the DJI Mic transmitter?
888 19 2-24 12:31
HGDC84
Finland
Recently, I have been doing some work projects that have involved the DJI Mic in them. The person filmed in the videos has the transmitter attached to his clothes using the magnets of the DJI Mic, which are supposed to hold the transmitter attached through the cloth between the magnets and the magnetic clip of the transmitter. However, the person in question is wearing a reasonably thick woolly jumper, and it is somewhat questionable if the magnets are strong enough to hold the transmitter in it's place through it. I would otherwise use the clip instead of the magnets, but using the clip places the transmitter too close to his chin, and if he turns his head, there is the risk of his chin coming in contact with the microphone and ruining the audio.
As I started to think of a possible solution to this problem, it came into my mind that there is a magnetic lanyard accessory available for the Action 2, and I started to wonder if I could use that to keep the transmitter at the appropriate place, the idea being that the lanyard is not put under the clothes but over them. If the pendant is of the right type, the transmitter could attach directly to it with no cloth in between, creating a more firm magnetic bond. The person in question is not involved in vigorous movements or exercise, just standing, talking, and at most walking in a calm pace, so no risk of sudden movement causing it to fall off of it.
Has anyone tried this? If you have, did it work out for you?
2-24 12:31
Blériot53
Flight distance : 6269839 ft
It's worth a try, I'd say.  Having done a fair bit of walking and filming with the Action 2 and battery pack around my neck, I can tell you it takes a fairly vigorous movement to detach it when there is no material between the magnet and the keeper. I don't think the DJI Mic is any heavier than the combined Action 2 and battery pack, so it should hold well.  Try it and see.
2-24 15:34
lutzmix
you can use the Telesin magnet mount
2-24 19:08
HGDC84
Finland
Blériot53 Posted at 2-24 15:34
I think that it's not the weight that would be the problem, the thing I am wondering a bit more about is if the whole pendant part of the lanyard is magnetic or if it's just the L-shaped bracket that is. I do suspect that the surface of the magnetic contact should be reasonably large and straight towards the DJI Mic's transmitter's magnetic clip in order to ensure the firmness of the magnetic bond.
Which part of the Action 2 attaches magnetically to the lanyard? Is it only attached at the bottom of the camera (the side with the contact pins), or is there some magnetic surface on the display side of the Action 2?
2-25 05:08
HGDC84
Finland
lutzmix Posted at 2-24 19:08
That looks like a very good option for this, thanks for the tip And if I have understood right, the Insta360 magnetic pendant designed for the Go 2 or Go3 camera could also work for this.
The reason I originally asked for the compatibility of the DJI version was that I have some DJI Credit available and was wondering if I could order that using the credits. But maybe I ought to consider the Telesin mount instead. Will have to see how it is available here in Finland. But overall, that might well be exactly the solution I am looking for, so thanks for that
2-25 05:12
Blériot53
HGDC84 Posted at 2-25 05:08
Both the flat pendant attached to the lanyard, and the detachable L shaped retaining bar, are magnetic independently.
2-25 05:42
HGDC84
Finland
Blériot53 Posted at 2-25 05:42
Good to know that, thanks for informing me Will have to seriously consider between the three options, depending on the availability and possible additional functions. The option to attach GoPro-type mount adapters to Telesin looks tempting, but I do wonder if the magnetic bond is strong enough to hold them in place with the camera mounted or whether I should go for a separate model where the mount is fixed in place.
2-25 05:49
Blériot53
HGDC84 Posted at 2-25 05:49
Magnetic mounts do have their advantages - but also limitations.  An inadvertent knock can cause them to detach.
2-25 06:01
HGDC84
Finland
Blériot53 Posted at 2-25 06:01
True that. I am not planning on any extreme mountain biking or other vigorous activities with it, but I still am a bit hesitant about it.
2-25 07:24
Blériot53
HGDC84 Posted at 2-25 07:24
I had that fright in Paris, you may recall, last February. The unit dropped off the lanyard and clonked onto the pavement.  Luckily, no damage apart from a tiny scratch on the case.
2-25 09:42
HGDC84
Finland
Blériot53 Posted at 2-25 09:42
Yes, I remember the incident. Probably worth bearing that in my mind. I assume you were not running, jumping or anything similar by then?
2-25 13:19
Blériot53
HGDC84 Posted at 2-25 13:19
No, I was just standing and may have nudged it with my arm or something.
2-25 23:40
lutzmix
you can use it!
without the small tx magnets
2-26 01:21
HGDC84
Finland
Blériot53 Posted at 2-25 23:40
Thanks for that clarification, will have to bear that in mind when deciding what would be the best model for me.
2-27 14:03
HGDC84
Finland
lutzmix Posted at 2-26 01:21
you can use it!
Thank you very much for pointing this out. Will have to consider a little which one to go for, but good to know that is one of the options if I decide to try to get the Telesin one and it's not available for some reason.
2-27 14:05
Blériot53
HGDC84 Posted at 2-27 14:03
Good luck with it
2-27 14:32
HGDC84
Finland
Thanks, I do believe I will figure out the optimal solution
2-27 14:54
lutzmix
sjcam magnet mount for c200  ca8€
5-23 21:48
lutzmix
lutzmix Posted at 5-23 21:48
sjcam magnet mount for c200 or c300 ca8€[Image]
the Ulanzi AM-18 transmitter is too wide
5-23 22:17
HGDC84
Finland
Good to know for others that there are multiple options. As for me, my problem is already solved as I went with the Telesin and seems to work great for me Anyhow, thanks for all the suggestions!
5-24 01:48
