Do RockSteady need higher shutter than Steady
216 2 3-21 11:59
eerikoo
I'm trying to understand the difference between RockSteady and Steady stabilization apart from the obvious crop Steady gives. Do Rocksteady require higher shutter speed than Steady does?
3-21 11:59
Hi there. Thank you for reaching out. Kindly please check the information below regarding the Steady and Rocksteady feature on your DJI Action 2:
Steady: The FOV is greater, and the camera consumes more power compared to the RockSteady mode. Videos can be recorded at a higher resolution. To record videos at a higher resolution for a longer period of time, it is recommended to use Steady mode.
The maximum video resolution is 4K/60 fps. The default Steady mode is applicable to most scenarios.
Supported resolution: 1080P24/25/30/48/50/60
2.7K(16:9)24/25/30/48/50/60
4K(16:9)24/25/30/48/50/60
RockSteady: In this mode, the camera operates with lower power consumption and can take longer videos in a high-temperature environment.
Supported resolution: 1080p Power Reserve mode 24/25/30/48/50/60 fps
1080P24/25/30/48/50/60/100/120/200/240
2.7K(16:9)24/25/30/48/50/60/100/120
2.7K(4:3)24/25/30/48/50/60
4K(16:9)24/25/30/48/50/60/100/120
4K(4:3)24/25/30/48/50/60
The maximum video resolution is 4K/120 fps. More computing resources will feed into the processor to produce more stable videos with a greater angle of view.
3-21 19:52
eerikoo
Hi, thanks for answer. But how can Steady have greater FOV and higher resolution? It is not what I see
3-22 06:12
