Avata Flops wont take off
2994 10 2022-12-29
Fout999
just took my new Avata out for a test run. using Motion Controller
first two attempts it leaned towards the front right prop and died.
third attempt i let the props spin a bit before attempting to take off. it started flopping around on the sidewalk.
any help? it almost seems like all prop motors arent synced up correctly?
this is my first FPV experience. bit disappointed.
2022-12-29
WernerD
Flight distance : 350837 ft
Austria
That is definitely not correct. You have to double click the red action button on the Motion Controller to start the motors. Then long click it to get the motors to speed and it lifts approx 0.5m above ground. And only then the inputs from the Motion Controller cause the Avata to turn and move.
So if anything else happens in the first take off phase, it is a faulty drone, nothing you are doing wrong.
2022-12-29
Fout999
WernerD Posted at 12-29 14:29
was thinking the same. going to try to see if there is potentially a calibration error and try again.
if that doesn't work i will have to send it back.
2022-12-29
Fout999
Man, i am a dumb###. changed the props (been a while) for some bright orange ones and forgot that there are specific props for each motor. think i had them mixed up. will test tomorrow but i am pretty sure that explains the hopping behavior.
been flying for 4 years and haven't changed props on a drone in 3 at least.
2022-12-29
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please double-check the propellers that you install on the unit and please install the propellers into the corresponding marked motor then check if the issue persists? You may refer to the tutorial video below (start @4:16) for your reference. Please keep us posted. Thank you.
2022-12-29
HDPS
Flight distance : 44957 ft
Recommend read the 81 pages Avata Manual, here:
https://dl.djicdn.com/downloads/DJI_Avata/20221208/DJI_Avata_User_Manual_EN.pdf
2022-12-29
Fout999
HDPS Posted at 12-29 20:27
Thanks. not finding the pdf at that link.
but i found it here.
https://www.dji.com/avata/downloads
2022-12-30
Fout999
DJI Paladin Posted at 2022-12-29 19:42
https://www.youtube.com/watch?v=CUQxj-JFm8M
The propellers being improperly installed was indeed the problem. launched with zero problems yesterday.
2023-1-2
Fout999 Posted at 1-2 07:07
Perfect! We're glad that you managed to isolate the said issue. Please don't hesitate to reach us if you have other inquiries. Thank you for your continue support!
2023-1-6
jakeflys
Flight distance : 1598481 ft
Thanks guys this helped me too! same issue.
3-27 09:38
jakeflys Posted at 3-27 09:38
Hello, Jake. We're glad that the solution above isolates your issue. If you have other technical inquiries or concerns, feel free to post them directly on the Homepage or send us a DM for further assistance. Thank you for your valued support!
3-28 01:42
