DJI AVATA 2 CE TO FCC , HOW?
9606 41 4-13 10:33
zippomakerhotmail.com
Flight distance : 123182 ft
Hi everyone, I tried to use the Avata 1 method to switch from CE to FCC with the file on the SD card but it doesn't work. I also tried to format the SD card directly from the goggle but it doesn't work, the button to switch between "auto" to "manual" is blank
any suggestion?
4-13 10:33
Hi there. DJI Avata 2 does not support manually switching among FCC, CE, and SRRC. The aircraft will identify the country and region where it is located according to the condition of the mobile device and the GPS of the aircraft, and switch between FCC, CE, and SRRC following local laws and regulations. Thank you for your patience and understanding.
4-13 20:31
Will manual switching be implemented in the EU?
4-14 12:51
747 Global Aerial - iamwhatiam
Hi !
As I have already checked and confirmed the fcc hack with the file worked fine until the time I did the latest update . Before I do the firmware update I did the jack and tarter the hack it appeared more channels and had better range . Now after the update the channels are  locked to auro and not possible to change anything and worse range.
4-15 10:51
Fozando
Flight distance : 818356 ft
747 Global Aerial - iamwhatiam Posted at 4-15 10:51
Hi !
So, is DJI blocking the use of hacks?
4-15 10:57
Black_Wolf
I consider this change from DJI  as a tragedy and the total downgrade of Avata 2 range and performance, the range has total dropped, the HD image is super low and you can't fly even between trees. DJI should provide the opportunity to unblock the FCC because it is a matter for the user, not DJI or the regulations, every pilot is responsible for the flights right?
4-15 11:46
Fozando
You should take a look to this:
4-15 12:07
SaurabhSrivastava
Flight distance : 2380479 ft
Do not update to 0.02 for avata 2 drone
It will break the FCC ham file mod and it won't work on it anymore. You will be stuck in CE mode if not in the US
4-15 12:33
alex_markov
Flight distance : 40068986 ft
Bulgaria
SaurabhSrivastava Posted at 4-15 12:33
I am not sure but I think when You activate the drone for a first time I think DJI mandatory upgrade to the latest FW
4-15 18:46
alex_markov
Bulgaria
This new development might be a deal breaker for me as Avata is meant to fly in dense environments (forests, canyons, etc.) and lost of signal is deadly for the drone
4-15 18:49
SaurabhSrivastava
As of now, only the drone tweaks modded fly app works and puts the avata 2 in FCC mode. It's a paid service and works even with the new firmware 0.02
No more free lunches by DJI as of now, but m pretty sure some hack will come as it will be a deal breaker for many in EU and other parts of the world
4-15 22:23
SaurabhSrivastava
4-15 22:32
Fozando
SaurabhSrivastava Posted at 4-15 22:32
https://youtu.be/uKvIkMoU7I8?si=LddFSbZsUtW9IHPI
All business, I can wait to purchase the Avata 2 until this situation with the transmissions be solved by a free hack and with a little luck the price goes down in the next months
4-15 23:19
djiuser_NfEOyidJBxAM
Philippines
Fozando Posted at 4-15 10:57
damnit! Mine will be arriving next week, this timing sucks. Now I have to stick with CE,
4-16 16:24
Fozando
djiuser_NfEOyidJBxAM Posted at 4-16 16:24
Let's ser if future hacks can solve the problem, but I prefer that DJI allows the posibility of exchange the C1 label for the C2 or C3 in order to no be restricted tobthe 19m/s
4-17 04:57
djiuser_nnZEm0tRdS7Q
Flight distance : 16841 ft
Google it and you find what you need. Or YT Mads Tech and also he said what must you do.
4-18 04:51
fichek
Flight distance : 1100308 ft
Croatia
EASA probably knew about the ham file and told them to remove it in order to get C1 certification. Hopefully there's another "accidental" hack in there that will be "discovered"
4-18 05:27
BadBert
Flight distance : 89751 ft
fichek Posted at 4-18 05:27
hope so!
i am planning on selling my avata 1 to get the avata 2.
i already seen video's showing the signal (range/penetration) is beter on the 2 than the 1 (even in CE mode), but the speed limit  puts me off... i know this is to get the C1 label!
4-19 01:13
djiuser_mlXjFtNRplCc
No entiendo, como DJI puede limitarse ante sus competidores quitandonos la posibilidad de disfrutar de sus productos al máximo rendimiento. Estaba a punto de comprar el controlador 3 para utilizar mi avata2 en modo manual, pero con esta limitación, ahora ya no es una opción interesante.
4-21 10:13
djiuser_cvhEHIaSFk1b
Estonia
Following. I cant justify to purchase avata 2 until this is fixed. 60km/h max and way worse range in EU compared to fcc outside EU is unbelievable. There must be option to change drone category. And EU is just a union, not a country. How come DJI set limit to all EU countries, we have different regulations for drones in different countries. Until that i will rather fly my mini 2 that has same top speed and way better range.
4-23 01:19
Luca Rubino
Flight distance : 711512 ft
djiuser_cvhEHIaSFk1b Posted at 4-23 01:19
In EU it means EASA countries (EU + some other countries like Swiss and Iceland I think).
Regulation class mark is the same all over these countries in EASA area.
The Avata 2 has a better range than a Mini 2 if you fly it like a Mini/Mavic drone. Up in the sky and not low, close to the ground and behind obstacles.
4-23 02:19
Estonia
Right, at the moment only solution seems to be to use DT 3rd party app. In case of crash, does DJI care still cover the repair when using 3rd party app? They likely use some diagnostic tool when it arrives to dji. Then again its possible to return your crashed drone in condition that no diagnostics is possible. At the moment according to DT it only neees to be connected to 3rd party app once, after that you can fly in official app in fcc mode. But this can change with future updates.
4-23 03:05
KREMi
nice vid, giving us little peek what is happening there, but now there is need for deeper run ;)
4-23 03:07
DubSound
Flight distance : 104459 ft
djiuser_cvhEHIaSFk1b Posted at 4-23 03:05
Use of third party apps is allowed, but if you crash using the third party app, DJI won't cover it under warranty.
4-25 23:36
fichek
Croatia
DubSound Posted at 4-25 23:36
Are you sure that applies to Avata and FPV Drone where DJI Fly is more of a spotter accessory and isn't really linked to or affecting flight in any way?
4-26 06:19
Moose1960
fichek Posted at 4-26 06:19
The drone has a transmitter and receiver and the controller has a transmitter and receiver.
Giving only the drone or the controller a higer RF outout won't help....
Gr
4-26 11:22
fichek
Croatia
Moose1960 Posted at 4-26 11:22
That's not how it works though, FCC mode activation puts both goggles and aircraft in higher power (and usually the controller, but with Avata 2 / Goggles 3 the controllers only pair and talk to goggles so the power needed is very small).
4-26 22:32
Moose1960
fichek Posted at 4-26 22:32
Both, the drone and the controller must have higer RF output. If only goggles or controller has more output power than the drone can receive the controller at great distance but the controller can not receive the weag signal from the drone anymore so both have to be updated to higher output level.
4-27 04:16
fichek
Croatia
Moose1960 Posted at 4-27 04:16
Again, that is not how it works. Goggles are the controlling device here, and their output power is increased in FCC mode along with aircraft’s power. The actual physical controller (both FPVRC3 and RCM3) only talk to goggles at low power and goggles relay their signal to aircraft.
4-27 07:35
Nitrosavy
I have a question regarding the hack, I’m in New Zealand where it is ce mode, I have downloaded and successfully installed the hack, it’s now showing extra channels in manual mode, my question is…for fcc mode do I just leave it in auto and automatically get extra power output or do I have to select manual? If so what should I choose in menu, any help for this newbie would be much appreciated. Apologies if I’ve posted this in the wrong thread.
4-30 22:05
fichek
Croatia
Nitrosavy Posted at 4-30 22:05
Definitely leave it in auto channel mode as it will hop around to better channels when there’s interference etc. there’s no selection of power with O3/O4, it’s always auto.
4-30 23:03
DubSound
It applies to any DJI drone. If you use a third party app to record to the flight data, DJI won't cover it under warranty if you crash. This is a blanket thing and applies to all drones that have SDK capabilities.
4-30 23:56
Nitrosavy
fichek Posted at 4-30 23:03
Many thanks.
5-1 16:38
Fozando
Mads Tech has recently posted another video on his Youtube channel in which you can see that the Ham file is really working, although you haven't manual channel selection.
5-1 21:18
airborne.clips
Flight distance : 1903875 ft
Portugal
you did FCC hack on avata 2? Can you explain how? is with the same ham file thing as on goggles2?
appreciated.
5-5 03:22
BadBert
airborne.clips Posted at 5-5 03:22
appreciated.
if you use the ham file, you keep the tri band function, more power, and remove the speed limit (c1 recuirement).
just can't select manual channels.
see: https://forum.dji.com/forum.php? ... p;extra=&page=2
5-7 22:53
Nitrosavy
appreciated.
Hi, I just downloaded the ham file, then you have to unzip it after that I transferred the file to a micro sd
card and put that in the DJI googles, put the card in before powering up the googles, after that I rechecked and found I had mutilple channels that I didn’t have before, and the range of my Avata 2 has increased a lot. One last thing I forgot to mention, make sure before loading the unzipped ham file on to the micro sd card that you format the card using the DJI googles, then the file will work on the sd card and be readable by the googles.
Hope this helps.
5-13 01:20
airborne.clips
Portugal
Ok thanks guys!
5-21 13:22
djiuser_d7X0e0n7Cg0o
Austria
I have the avata 2 with the old firmware and im not sure if i should use the ham hack. when i‘m using the ham file can i still use my DJI Care? It isn‘t a third party App.
6-3 13:20
djiuser_Ve6IU7YPhdqU
DJI Tony Posted at 4-13 20:31
Wrong.  It can be mentally and permanently switched from CE to FCC using the DroneTweaks app.
6-3 17:19
