Updated my Phantom 4 PRO+ v2 firmware using DJI Assistant and direct USB cable connected to Drone. After update DJI Assistant says the firmware is current. Every time I start the controller up and it connects to the Drone I get the message"New firmware is available > Phantom 4 PRO+ v2.0 01.00.7017" Why do I keep getting this message on the Controller when the firmware has already been updated on the Drone?
Hi there. Can you please double-check if you have the latest firmware by checking the " About" section in the general settings? The latest firmware is v01.00.70.17. Thank you.
Thanks Tony, Here is a photo of what the DJI Assistant shows. It says the Drone's firmware is current but the controller still say that New Firmware is available. You want me to check elsewhere for something?
Marshall T. Did you ever resolve this issue? I am currently experiencing the exact same problem. DJI Assistant 2 says the drone firmware is the latest, but the controller says I must update to be able to fly the drone.
