John Anderson
I wanted to test that the gear was functioning and it wasn't as if I just flew.. no, I powered up and check that everything was normal and that the motors rotated. If not, the motors were damaged.. and luckily they weren't so I give it some power, tested the gear, landed and packed up. I knew what needed to be repaired so I went straight to the retailer at the mall near me that stocks all the parts.
Don't think I was being reckless.. no, I was expecting to go up 2 meters. Not full speed reverse into a wall. Afterwards I needed to know what was next, and I repaired the aircraft in the very shortest space of time. 3 days.. just the props needed to be ordered.
It doesn't fly better or worse than before.. it's exactly the same. Flight data is indistinguishable from before the crash. I must be doing something right after all.
If you think that the RC is extremely good quality then you're easily amused. It cost a lot of money, as did the aircraft and the five batteries and the gopro I strap to the wing. I want children to sing songs about the controllers that the Inspire 1 comes with and at the moment, no little village children will be singing any songs about it. Because it's a Phantom 3 controller. Not the Inspire 1 v2 (2016 spec) controller I was expecting, I believe my reaction was FFS. |
