Polar Pro LED Kit Interference?
1769 9 2016-3-10
jcarlson1701
Hello all,
I know this subject has been touched on before but I wanted to get a consensus from everyone that has the Polar Pro LED Light kit
https://www.polarprofilters.com/ ... tom-3-led-light-kit
Has anyone had any issues with GPS reception with the battery being mounted to the top of the Phantom (P3A in my case) or the lights themselves being mounted on the legs/antennas?
It just seems to be an odd placement decision on Polar Pro's part...
I'm really considering purchasing the kit but not at the expense of my P3A's safety.
2016-3-10
mal6514
No. No affect that is obvious to the naked eye as far as I can tell. Easy on/off install and looks great and helps with orientation from afar  -day or night . I chose to install backwards(?) with red lights in front and white towards rear . - since the phantom 3"s current led setup is red to the front and green to the back . Keep in mind these are for to help you see the bird. Not to help u see though fpv
2016-3-11
ChaneRZ
Flight distance : 171043 ft
I have one and doesn't interfere at all.
2016-3-11
DJI-Tim
I wouldn't recommend this led kit at all cause it covers the GPS on top of the aircraft so it can influence drone performace
2016-3-11
jcarlson1701
DJI-Tim Posted at 2016-3-11 04:45
I wouldn't recommend this led kit at all cause it covers the GPS on top of the aircraft so it can in ...
That's what I thought and what's keeping me from purchasing it. However I have seen that many Phantom owners on the forums use this kit without issue so I'm still split on whether to get it or not...
2016-3-11
DJI-Tim
jcarlson1701 Posted at 2016-3-11 22:58
That's what I thought and what's keeping me from purchasing it. However I have seen that many Phan ...
for 50 bucks... i would think about it...
2016-3-11
fanscc07be79
Flight distance : 117936 ft
I just bought the kit from Best Buy for $27.99.  It's awesome!  fits very nicely.  Lights are very bright.    I don't have the best GPS availability around my house in my yard.  Normally my PS3 lands very close to the home point and hovers very nicely in place.   I put the LED kit on the drone with the Customer top mounted battery and the drone acts weird. Hovers erratically and drifts & Returns home, but not very accurately like before.  Not flyable within safety limits.  I will try the P3S and the LED kit in an area with full GPS coverage to see what happens.  To be continue.
2017-6-30
RedHotPoker
Flight distance : 165105 ft
I would like to suggest another much brighter kind of LED lighting for your drone. ;-)
http://forum.dji.com/forum.php?m ... 7&fromuid=38998
Hope you find a simple solution to your situation. Good luck.
RedHotPoker
2017-7-1
fanscc07be79 Posted at 2017-6-30 23:10
If you read this thread from the beginning, DJI-Tim advises against mounting anything on the top of the aircraft. The GPS receiver is just under the top and you are blocking reception by placing the battery on the top.
2017-7-1
RedHotPoker
Geebax Posted at 2017-7-1 01:28
That's certainly a poor choice for their battery location, above the sensitive GPS... Too bad.
RedHotPoker
2017-7-1
