Dear Kevin hope you get the matter sorted . The guys here Ken Tim and Paladin are good. .BUT the technicians believe every thing the flight records say which is wrong . My Phantom 3 Standard I bought on 20th refused to rth even had the RTH set at 30metres . Dji Holland blame bad area . Not optimal signal . Keep fighting Kevin . DJI make good drone but need to stop telling customer at fault .
My phantom standard cost me 650 dollars in us money . The telling me I have to pay costs yo fix it . I only had it since 20th . I am hurting and depressed . I wanted to enjoy the Drone and I have nothing .
Hi Kevin I hope you get it sorted . I'm still fighting to dispute there claims . DJI need to know not everything is perfect in the Phantom Standard . To be told I flew drone in non optimal area is poor reply as I flew there before . 450 UK pounds may not be much to DJI but it's a lot to me .
Kevin,
I am sorry, they re-evaluated and the flight data recorder shows that one motor spun full throttle and the only way that can happen is if the prop came off.
I am sorry, but the re-evaluation is a final decision.
Firmware updating will not cause a hovering aircraft to flip over while hovering.
Kevin,
You are absolutely free to do whatever you feel necessary to try and get a different resolution.
I assisted you quite a bit last week and even had your aircraft re-evaluated and a different tech came up with the same conclusion.
I am sorry, but as the DJI management also emailed you stating after the 2nd evaluation the case still stands as the prop was not tightened enough.
There is no way that a motor can spin up that fast unless it loses a prop.
I am sorry about your crash, but DJI stands on its decision that it is not a warranty claim.
Please respond to the email if you want the aircraft to be repaired or returned to you.
DJI-Ken Posted at 2016-5-4 10:35
Kevin,
You are absolutely free to do whatever you feel necessary to try and get a different resolut ...
There is a way a motor can spin up without losing a prop, and it happened to me. Your Techs just didn't want to agree with that. The flight data clearly shows another motor dropped in speed.
I wish I had a video of the flight to prove you all wrong.
The Video has been removed as DJI has sorted out the issues.
- REMOVED
While it gives me a little more confidance in DJI's ability to fix problems, I will admit that I will be very hesitant to fly the drone when I get it back.
