"Weak image transfer signal" after update new Dji Go App !!
44630 420 2016-5-25
ranchn1377
Flight distance : 292244 ft
Israel
Another issue that I've found in this version is that all of my flight simulator flights are saved as normal flights
2016-5-27
Davidj7
cayalag Posted at 2016-5-27 09:34
davidj7 if you are using and iPad mini, first generation... that's the problem.
Really? yes, its a mini iPad 1.  I had a feeling that it was a little outdated and might be the cause. If thats the case ignore my post. I'll be looking to upgrade soon then.
2016-5-27
cayalag
Flight distance : 470656 ft
Portugal
Yeap, unfortunately the processor can't handle the APP. If you take a look at the Phantom's box you'll see the minimum is an iPad mini 2...
I tried myself as well, and had your same issues.
2016-5-27
vad7
ranchn1377 Posted at 2016-5-27 23:42
Another issue that I've found in this version is that all of my flight simulator flights are saved a ...
Train as you fight, Fight as you train.
2016-5-27
bmetz9
Dji guys any action on a possible fix? Pretty disappointing going into a holiday weekend.
2016-5-27
mactech
bmetz9 Posted at 2016-5-27 10:39
Their reply will be something along the lines of
• this happens on only a few iOS devices
• this doesn't happen for anyone at DJI
• suggest you spend time rebooting, reinstalling
• this affects a very limited number of users so it's just your problem
2016-5-27
delignejose
Flight distance : 1093248 ft
They say the fix should be up by end of day
2016-5-27
mactech
delignejose@hot Posted at 2016-5-27 10:52
I hope you're right about that.  However, not sure how they can fast track Apple to get an update on the store that quickly short of restoring the previous version already approved.
2016-5-27
mavs88
Flight distance : 8953215 ft
May 27th... Lovely weather... a little breeze...
I just got the chance to fly... using the latest DJI GO app...
In my case I also get black screens and a few black stripes... As many people already reported, mentioned, placed pictures and videos... I think I do not need to do that... The smae problem which, like all other users, did NOT show up using je DJI Go APP v. 2.8.1
besides....
DJI (friends) just now I checked again and my Phantom 4 also looses altitude and regains and drifts (just a little bit, but too much).
The same happened after a 2nd or 3rd firmware update of the Phantom 3 Pro which I owned before. The 3rd or 4th firmware update made the Phantom 3 solid as a rock.
I do hope DJI is taking this (and the (iOS)app-problem since 2.8.2) SERIOUS... I would like to fly in a nice and usual SAFE way before DJI will come out with the Phantom 5 or S or SE
Regards,
Max
Phantom 4 and RC all latest update
Apple iPad Pro 9.7" (iOS 9.3.2 final)
FULL fresh charged original DJI Battery... (flown 4 times with this one, my battery number 3)
2016-5-27
mavs88
delignejose@hot Posted at 2016-5-27 16:52
ehm.... which day this year...?
2016-5-27
markkluge
cayalag Posted at 2016-5-27 20:48
stupid question but... have you previously deleted the new one ?
Yes. I deleted the app, reinstalled, and relinked. Had the same issues.
2016-5-27
jackramsdale
Flight distance : 283619 ft
for what its worth  -- I am using V 2.8.1 on my ipad mini.  I had the same video signal problem that most are describing, when I went to fly yesterday.  May 26, 2016.  A flight on May 24th and before I have not had this problem.  I was flying in an area I have flown a hundred times before, in a field.
The only difference I see in my experience is that I am still using version 2.8.1  - .
Just as frustrating as everyone else's video link.   This is on my phathom 3 pro
I will check the video signal and also try a different software program next time out.
2016-5-27
radiomike
Flight distance : 82438 ft
DJI-BladeStrike Posted at 2016-5-26 10:22
Can you guys that are having issues please sync your logs and completely remove the app, reboot the  ...
Hi, I also have flown many flights with no issue and on the first flight with the new app I received the image transmission warning and had the colored bars and transmission breakups.
I will upload files
2016-5-27
imagesbyjas
Flight distance : 286198 ft
jackramsdale@ya Posted at 2016-5-28 00:58
for what its worth  -- I am using V 2.8.1 on my ipad mini.  I had the same video signal problem that ...
iPad mini or mini 2?  I'm on 2.8.1 DJI GO, 1.8 AC, and 1.6 RC with latest IOS (9.3.2).  No drop out issues, and got a weak signal warning 7,000 ft out through a tree line but still was transmitting video.  P3P (Model 323 (oldest), not A or B - if that makes a difference).. RC is B model.  So that could/should be at a minimum a benchmark.  I STILL wonder if these updates take into account all variations (as best as they can test) of the aircraft... The most sigificant was the last one when the main board was also changed in support of the motor change.
We know for certain that A, B and C aircraft models had different power ratings submitted to FAA..  Don't know if there is anything related to the A or B model Remote Control.  Perhaps a good idea when reporting these things now if we all list the specifics of our units (not serial #'s but generic things) like I'm mentioning..  Also, and let's be honest as possible.. any hardware mods to RC or Bird that have been done, etc..  Just a thought to help DJI debug or try to narrow down?
2016-5-27
bugsy47131
Flight distance : 879639 ft
Add me to the list.
iPhone 6S Plus
installed new update and had the same issues while trying to hover right in front of me.
2016-5-27
Capt. Wild Bill
Flight distance : 1319180 ft
imagesbyjas Posted at 2016-5-27 13:47
iPad mini or mini 2?  I'm on 2.8.1 DJI GO, 1.8 AC, and 1.6 RC with latest IOS (9.3.2).  No drop out ...
The recent weak signal/disconnect issue stems from 2.8.2.
2016-5-27
Iiikabiii
So obviously this is only a problem with dji go app and not litchi? I haven't been able to fly since i updated the dji app but when i do and if i have issues ill just go buy the litchi app and ditch dji go
2016-5-27
imagesbyjas
Capt. Wild Bill Posted at 2016-5-28 01:56
Not disagreeing at all, but wonder (as I mentioned) if it is all combos of hardware?  I'm assuming Litchi is using the SDK which may (or may not) change with each fw change..  We don't know if the same is true for the DJI GO app..  It may be talking at a different level to the RC and Aircraft.. I can't imagine that there isn't SOME testing done by DJI before this goes out the door.. how much we don't know.. on how many different machines or combos, we don't know..  I read somewhere there's like 37 variations on the P3A and P3P.. how do you test on each and every one..  Maybe this one hits them all, but you'd think SOMEONE in the testing group would have seen it..
2016-5-27
ville.honkonen
Flight distance : 80919 ft
Finland
Iiikabiii@gmail Posted at 2016-5-27 21:01
So obviously this is only a problem with dji go app and not litchi? I haven't been able to fly since ...
Yes, like almost 100 posts says.. iOS Dji Go app version 2.8.1 is working perfect, but 2.8.2 you lose signal etc.
2016-5-27
cegd2000
Flight distance : 133734 ft
Mexico
sploodge Posted at 2016-5-27 14:59
Still goes through Apple approval process so will not be instantaneous..
if you want the previous  ...
This is how I got the 2.8.1 version, it works great
2016-5-27
ranchn1377
Israel
sploodge Posted at 2016-5-27 09:59
Sploodge! Thanks allot for the link! Fixed my problem
2016-5-27
Pipobike
Liechtenstein
rreindl Posted at 2016-5-26 16:57
This worked for my P3A. So far I would say about 10 flights tested.
Did you also re-link?
2016-5-27
imagesbyjas
Anyone check their cloud backups on iCloud to see if you have an older (as in a couple of days) backup that would have had 2.8.1 on it and not 2.8.2?
2016-5-27
cegd2000
Mexico
imagesbyjas Posted at 2016-5-28 04:16
Anyone check their cloud backups on iCloud to see if you have an older (as in a couple of days) back ...
cayalag Posted at 2016-5-27 07:29
and still no fix... NICE !
Is it that difficult to admit it and make 8.2.1 accesible to public agai ...
if you want the previous version ( and no need to reinstal from a backup ) you can follow this guide to get the previous version.. Its not a simple process but I have done it and does works..
EDIT: Works on windows also.. same process really..
http://www.idownloadblog.com/201 ... rsions-of-ios-apps/
I think you need to download your own app cause it is linked to the itunes account, you can follow this post to achieve that. It works
2016-5-27
streetperformer
DJI-BladeStrike Posted at 2016-5-26 16:44
I appreciate you understanding.. Please try the suggestion even if you have tried before.
If you ...
Hello i live in sweden were i van not change Chanel. I just got My plantor 4 and Are verry disapointed with The bad conection. I have tråd IT on both  iphone6+ and an iPad 3 mini with The same por result allt Of The time The image is just Green  is three alternative asp For The P4
2016-5-27
pocketpair25
Same problem here, now.  Everything is up to date, no problems before DJI GO app update two days ago.  I hope this gets fixed very soon.  Very frustrating.
P4 (latest firmware) DJI Go app (most up to date version) Ipad Mini 2 with latest version of IOS.
DJI - Please fix this.  Honestly, everything worked great before this latest DJI Go update.  I have logged 43 flights (13.5 hours) with not one problem before this update, now I can't even fly it out of my yard before image transmission/screen freezing/pixilating issues.
2016-5-27
BalooDK
Flight distance : 687598 ft
sploodge Posted at 2016-5-27 08:59
This took me some time to manage, but finally worked. Back on 2.8.1 now
Thank you
2016-5-27
delignejose
Balodk how did you manage to do it i  tried no luck here
2016-5-27
anders_alergard
Flight distance : 708264 ft
Having the same problem as everyone else with the bad video link. Hope they fix it soon. Along with the gimbal tilt problem they have.
2016-5-27
RocketBrew
Flight distance : 9681073 ft
It would be interesting to get a matrix of what configurations are affected or not affected if everyone could post a full set information. I recall the only post I saw that is not having problems listed an older iOS version, this would help show that.
What version is:
iOS:
Go App:
AC model (W323A, W323B, etc.):
AC firmware:
RC model (GL300B, GL300C, etc.):
RC firmware:
2016-5-27
BalooDK
delignejose@hot Posted at 2016-5-28 00:43
Just keep trying. I went through the guide 3 times to get it working... took me an hour ;)
2016-5-27
delignejose
Thanks baloodk
2016-5-27
imagesbyjas
cegd2000 Posted at 2016-5-28 05:05
I think you need to download your own app cause it is linked to the itunes account, you can foll ...
If you had 2.8.1 on your back up that's what will come back on the device.  Try to do the restore through iTunes..  I did that in the past with 2.7.1 and 2.8.. I got the app update notification after the restore that DJI GO app had an update.  I have automatic updates turned off..  HIGHLY recommend this setting..  I know, it's a pain to check every so often, but it's better than the alternative.  :-\
2016-5-27
jhonkaheimo
delignejose@hot Posted at 2016-5-28 06:43
Took me 10 mins to roll back to software if you watch that video that was posted above it works.
2016-5-27
imagesbyjas
RocketBrew Posted at 2016-5-28 06:53
It would be interesting to get a matrix of what configurations are affected or not affected if every ...
Great minds think alike...  I posted similar thought in #175 and #177.  There are a LOT of permutations out there.. I'm guess they can't physically test each and every one (not saying that's right or wrong).. probably reality though...
Suggestion to DJI from a long long long time coder..  Get to a stable base for ALL devices, isolate code branches that WILL differ based on hardware and test to make sure each of those branches all end up at the same next step..  Has to get done with this many different versions of the same aircraft and RCs..  Otherwise it will get worse before it gets better..  :-(
2016-5-27
delignejose
Jhonkaheimo do you have a link to the video
2016-5-27
jsdondelinger
Having same issue here with glitchy video transmission on 2.8.2 and on a brand new p4 out of the box on my iPad mini 4! Also tried re-installing app and re-linking RC as suggested earlier, but no luck of course! Absolutely no issue on my iPhone 6 with older 2.8.1 version! Bummer part is I'm on my second p4 now as I just exchanged my old one out at the Apple Store due to a different video transmission problem, or complete lack there of, which I started a thread on the forum a few days ago. So guess I'll have to wait a little longer to fly until an update comes out, unless I use my iPhone 6! Note to DJI: I will try to get a video out for you of the issue if you would like another one to show! Anything to help!
2016-5-27
jhonkaheimo
delignejose@hot Posted at 2016-5-28 07:26
Watch the video carefully.
Cheers!
The version number you want is "817278603" for 2.8.1
2016-5-27
delignejose
Thanks jhonkaheimo
2016-5-27
rreindl
Flight distance : 6491926 ft
Nope I did no re-link.
2016-5-27
