Planes flying low
4872 48 2016-6-25
nickmedici
Flight distance : 88287 ft
Who is at fault if my drone crashes into a plane but there is not airport within 5 miles and planes are flying below 400 feet? I'm at a lake and these water planes keep flying really low.
2016-6-25
Airspace Explor
Can the manned aircraft pilots see your drone? The right thing to do will come from your answer to this.
2016-6-25
gil
Flight distance : 1379308 ft
Do you mean seaplanes and amphibious aircraft?  Well, consider this, if your quad falls out of the sky there is little risk to life, if one of those "water planes" falls out of the sky there is HUGE risk to life -- you need to avoid any possible proximity to those planes!
I would also highly recommend you contact the nearest airport or air traffic control center to see if it is designated as any kind of a seaplane landing area.  Even if it isn't you should notify them beforehand when you are flying in the area so they can, in turn, alert any planes in the area to be aware of the potential risk below 400 feet.  You might even get your own DROTAM (Drone Notice To Airmen)
If you really want to be responsible you can look up and get familiar with the the Aeronautical Charts for your area at https://skyvector.com/
As an example, Ft. Campbell, Kentucky is 60 miles from where I own a house close to Kentucky Lake.  It never occured to me that if I were to hop in my 4 wheeler and drive down to the nearest point with my Phantom I could potentially fly into the CAMPBELL 2 MOA (Military Operations Area)
2016-6-25
labroides
Planes aren't automatically limited to above 500 feet and you can expect to see them lower.
It's up to you to keep out of their way.
Here are the FAA rules regarding minimum safe altitudes for planes.
Note C & D
§ 91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters, powered parachutes, and weight-shift-control aircraft. If the operation is conducted without hazard to persons or property on the surface—
(1) A helicopter may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section, provided each person operating the helicopter complies with any routes or altitudes specifically prescribed for helicopters by the FAA
2016-6-25
leonardk12.comc
If the lake is used by the airplanes that can land on water, then would the lake be considered an airport? The same as a small remote grass or dirt landing area is called an airport. Then you would be responsible I suspect.
2016-6-25
rreindl
Flight distance : 6491926 ft
Please what ever you do stay out of the way of any planes! Focus on what's really important, human life and our hobby. I sure would not want to read about you in the the paper!
2016-6-25
nickmedici
So what I'm not suppose to fly my drone? There should be something or some sort of database that shows when and where a plane is gonna land of it's going to. How am I suppose to know if there's a plane?
2016-6-25
EdM
Flight distance : 1491814 ft
nickmedici@bell Posted at 2016-6-26 07:37
So what I'm not suppose to fly my drone? There should be something or some sort of database that sho ...
You are supposed to remain in constant visual contact and control over your RC aircraft so you can avoid causing a problem for full scale aircraft.
2016-6-25
Michael M
Flight distance : 1984898 ft
The fact that you are asking a question like this is pretty scary, you are required to know where your done is at all times. No flying with earbuds in, listen and look for any aircraft. If you crash into them regardless, you are in huge trouble. Be careful, doesn't matter what anyone says, a phantom is not a toy.
2016-6-25
nickmedici@bell Posted at 2016-6-26 09:37
Well, you could try searching for an app that tells you when a plane is going to fly close to your drone.... or you could do what everyone else does and that is NOT FLY anywhere near that area. Your replies sound like you think you have a god-given right to fly anywhere.
2016-6-25
amelia.bolli01
Geebax Posted at 2016-6-26 07:58
Well, you could try searching for an app that tells you when a plane is going to fly close to your  ...
He is following all FAA regulations and restrictions so.........
2016-6-25
amelia.bolli01
I would suggest contacting the airport or airspace manager around the area you fly in and tell them politely that you are worried about your drone hitting a plane because they fly low, even though you are flying below 400 feet and following all FAA regulations.
2016-6-25
amelia.bolli01 Posted at 2016-6-26 15:26
I would suggest contacting the airport or airspace manager around the area you fly in and tell them  ...
Pardon, but it does not matter, he has to get out of the way of the full sized aircraft. They have right of passage over the area.
2016-6-25
RedHotPoker
Flight distance : 165105 ft
Let's just play tag with an airliner? Hahaha
Some people simply don't belong in our hobby-sport, or the lifestyle...
They aren't prepared to understand, what serious consequences are...
RedHotPoker
2016-6-25
VisionAir
Flight distance : 954665 ft
I don't know what the USA requirements are but here in Australia I have not long ago received my Commercial  Remote Pilot Licence (RoPL) and part of the 6 day course was we also obtained our Aircraft radio licence so if we are in the vicinity of any airport Within 10 nautical Miles we can talk to all aircraft in the area and if need be we can talk to Air Traffic Control of the airport if it has a tower,  so maybe find out what the requirements are for obtaining a Aviation radio licence...just a thought.
2016-6-25
VisionAir
labroides@yahoo Posted at 2016-6-26 03:42
It's up  ...
Also Aircraft can legally go as low as necessary to avoid Inclement weather.
2016-6-26
charlieb111
Flight distance : 67808 ft
There should be a database that shows if a dumb ass owns a drone
2016-6-26
Cetaman
Flight distance : 2528264 ft
nickmedici@bell Posted at 2016-6-25 13:37
Aloha nick,
     This is from the new Part 107 rules.  You may need to figure this out.  There are many other applicable rules including how to fly in the vicinity of heliports and airports without control towers.  Each one is different.  The best advice is duck and get out of there never to return.  Find another site to fly.  It is a big country.  As an alternative, do your job as an operator and keep an eye out for manned aircraft and stay out of their way.
     § 107.43 Operation in the vicinity of airports.
No person may operate a small unmanned aircraft in a manner that interferes with operations and traffic patterns at any airport, heliport, or seaplane base.
Aloha and Drone On!
2016-6-26
Cetaman
amelia.bolli01 Posted at 2016-6-25 19:26
Aloha amelia,
     There are separate rules for airports with and without control towers, also heliports with and without control towers.  As of August 21st, sUAS and micro UAS operators will be in a whole new world.  Best to start reading now.
Aloha and Drone On!
2016-6-26
rodger
Flight distance : 20145135 ft
I believe the manned Aircraft has the right of way. Anyway, that makes sense to me.
Common sense should be supplied here my friend.
Here is my situation. I live outside of the 5 mile marker of two Airports. One being a very busy and large Commercial Airport. I have never seen a plane be it commercial or private lower than 2-3,000 feet.
The second Airport is a small commercial and Military Airport, again over the 5 mile marker. The Military uses Black Hawks and C 130 Hercs. The Black Hawks usually stay around the thousand foot or higher mark. The Hercs are a different story. They are usually low in height. Some times at tree top level practicing Radar Evasion. If they are up, I am down. That simple. Would my Phantom cause any harm to a C130? Really doubt it. Would a C130 harm my Phantom? I am sure you know the answer to that. If there were an incident and I was below the 400 foot ruling would I be in trouble? Most likely because the C130 is a manned Aircraft. Just imagine all of the negative reactions and publicity. "Drone Strikes Air Force C130"
Hope this answers your thought.
2016-6-26
nigelw
Flight distance : 518084 ft
Does it matter who's at fault if people die as a result?
2016-6-26
Cessna172
The essential thing to this question is this......
MANNED "aircraft" ALWAYS have right of way vs UN-MANNED aircraft.
Any aircraft under maneuverable control that is not manned (has no humans onboard) MUST yield right of way to any maneuverable aircraft that has humans on board.  In addition, speaking strictly of manned aircraft, more maneuverable aircraft generally must yield to less maneuverable aircraft.   (Cessna vs occupied hot air Balloon for example)
So regardless of where the incident may occur, you are required to make sure your drone remains clear of any manned aircraft, under any circumstances.
An aircraft with people onboard "could" be below 400ft due to an in flight emergency for all you know.
This is probably the primary reason that you are required to maintain visual VLOS at ALL times.
2016-6-26
185EZ
Flight distance : 396470 ft
Had 4 helicopters flying around for a boat poker run.
I didn't fly out very far since they would circle back for the next group
you can see one coming on the left of the screen and I turned to come back to shore
I wasn't very high
yes I suck with the video controls
2016-6-26
j5255
Flight distance : 5291158 ft
185EZ Posted at 2016-6-26 16:34
I didn't fly out very far since they would cir ...
Please, find a safer place to fly.
2016-6-27
185EZ
j5255@yahoo.com Posted at 2016-6-27 10:20
lol, ok
maybe a cemetery
nobody will get hurt there
2016-6-27
j5255
185EZ Posted at 2016-6-27 16:41
lol, ok
maybe a cemetery
I think you have reached the limits of my medication
2016-6-27
soundbyte58
Flight distance : 300761 ft
amelia.bolli01 Posted at 2016-6-25 22:26
I think you should maybe read the regs. Unmanned craft are required to give right of way to manned aircraft, it's that simple. If your drone is close to a plane it is your fault not theirs and it is your responsibility to maintain separation. There is no minimum altitude over open water. There is a separation distance that must be maintained from people, vessels, vehicles & structures. Think of it this way...If you have a 500' restraining order against somebody, they have to stay away from you. However, you don't have to stay away from them. If you move close to them it's their responsibility to move away.
2016-6-27
amelia.bolli01
charlieb111@att Posted at 2016-6-26 16:41
And you are that dumb ass owner.
2016-6-27
soundbyte58
nickmedici@bell Posted at 2016-6-25 16:37
Excuse me, did I understand your question correctly? How are you supposed to know there is a plane? Sorry for the rhetorical questions but, ARE YOU DEAF?
2016-6-27
soundbyte58
Chris512 Posted at 2016-6-27 16:02
" There is no minimum altitude over open water. "
There is no minimum altitude for manned aircraf ...
Point taken, I didn't mention  sparsely populated areas because the OPs discussion was concerning seaplanes over a lake. That being said, we both know there's no cure for "stupid" and anybody suffering from this common condition should pick a hobby that doesn't  require conscious thought.
2016-6-27
soundbyte58
Chris512 Posted at 2016-6-27 20:01
What happened is that that the proliferation of relatively inexpensive turn-key RC aircraft, that  ...
Absolutely! Kids that aren't old enough to drive are getting them from their parents and flying without any supervision. As far as I'm concerned, deliberately flying a drone close to an operating aircraft is no different than dropping rocks from an overpass. Eventually someone is going to die.
2016-6-27
Cetaman
Chris512 Posted at 2016-6-27 13:02
Aloha Chris,
     Do they call you shredder?  Dude, that is one mean ass machine you fly.  I guess you fly drones for relaxation, kind of to get the white out of your knuckles after you pry your hands off the stick.  So, how fast does that puppy fly at 8 feet AGL?  I am having a heart attack just thinking about it!
Aloha and Drone On!
2016-6-27
soundbyte58
Chris512 Posted at 2016-6-28 10:47
I don't think that their parents really know much better either.  The problem, as I see it, is not ...
I agree with you, there is a lot that needs to be learned, and there is a lot that should be plain old fashioned common sense. Hence, my comment about stupidity. It was a figure of speech, not be taken literally. I don't think you'd really be hanging a ten year old's carcass out to dry.
2016-6-28
Westside Osprey
Flight distance : 95915 ft
As stated earlier. It is a good idea to study sectional charts of the area you plan to fly in.
Here is a great place to find them online for Free: https://skyvector.com
It shows airports MOA's (military operational areas) often fast A10's 100' AGL where I live, it is on the Chart below, Yankee One MOA.
The key is know where you are and always keep your MR in sight fairly close, so you can get out of the way of any aircraft. There may be a Crop Duster or a SAR aircraft that suddeny appears in unpopulated areas and Medevac helis fly and land pretty much everywhere. So keep your MR close and listen for any aircraft at all times. And of course never fly above 400' or in a place you cant just dive the MR out of the way just in case...
And bear in mind that even lakes w/o official seaplane base status often have aircraft land and T/O or practice T&Gs. I also often fly my Cardinal 500' out from the beach well below 500', as do a lot of other GA pilots, so be careful along the coasts as well.
2016-6-28
malvern
Step 1:  Arrives at lake to fly phantom.
Step 2:  Observes manned aircraft activity flying low.
Step 3:  Go home or find another lake with no aircraft's flying low.
It really is that simple.
Public safety first
Your safety next.
Then the Phantoms comes last.
So if you are flying your phantom, and a manned aircraft approaches, and you have but seconds to react, what do you do ?
Do you know how to kill the bird dead in the sky ?
2016-6-28
Cetaman
Chris512 Posted at 2016-6-28 04:40
Application speed is 120 kts.  And yes, the AT-series is a huge step forward from the old Cessna A ...
Aloha Chris,
    Sounds like you have the best of both worlds.  So, threading the power line needle huh.  Wow!
Aloha and Drone On!
2016-6-29
alexassenmacher
Flight distance : 216430 ft
One this is to follow restrictions and regulations. Another thing is not having common sense. Another one is even asking a question like this.
Having a drone requires a responsibility. If you do see a plane close to the area you are flying, just land your drone and go somewhere else. It's good to ask yourself is that area would be like an airport or if you could even fly close to the area, it's ok, but please you're risking human lives. It's hard for me to understand that you can get serious about your question.
Please droners, you have responsibilities and one mistake affects us all.
2016-6-29
soundbyte58
malvern Posted at 2016-6-28 16:45
If there was a lot of traffic, it would be best to find a friendlier playground. However, I cannot imagine a scenario where a common seaplane is going to sneak up on you. I live on the north coast of British Columbia where seaplane traffic is a fact of life. They are relatively easy to hear coming before you see them. You need to keep your head on a swivel and maintain situational awareness. It's not that hard to maintain proper separation. Another thing that could be helpful is carrying a scanner. the radio chatter could give you information you can use to keep it safe. If you have a restricted radio operator licence, that would be a bonus.
2016-6-29
soundbyte58
Westside Osprey Posted at 2016-6-28 12:56
Here ...
Perhaps you could provide me with an answer to a question I've been pondering. I live very close to an ADIZ and off the coast we have a large group of islands that are right in the center of the zone. I cannot find anything in the regs about how to fly a drone while inside the ADIZ. Would you be able to shed some light? Most consumer drones don't have the range to reach the the zone from the mainland, but there are areas where islands can be in the zone.
2016-6-29
Westside Osprey
soundbyte58 Posted at 2016-6-29 10:23
Perhaps you could provide me with an answer to a question I've been pondering. I live very close to ...
Basically you have to contact ATC to enter a ADIZ:
Air Defense Identification Zone (ADIZ)
All aircraft entering U.S. domestic airspace from points outside must provide for identification prior to entry or exit. ADIZs have been established to assist in early identification of aircraft in the vicinity of international U.S. airspace boundaries (AIM Section 6, 5-6-1).
Many aircraft inbound to the U.S. will cross an ADIZ. There is no ADIZ between the U.S. and Canada. According to FAR Part 99, if penetrating an ADIZ, all aircraft of U.S. or foreign registry must file, activate, and close a flight plan with the appropriate aeronautical facility. In addition to normal ADIZ position reports, and any other reports Air Traffic Control may require, a foreign civil aircraft must give a position report at least one hour before ADIZ penetration, if it is not more than two hours average cruising speed from the U.S.
For Defense VFR (DVFR) flights, the estimated time of ADIZ penetration must be filed with the appropriate aeronautical facility at least 15 minutes before penetration, except for flights in the Alaskan ADIZ, in which case, report prior to penetration. Additionally, VFR pilots must receive and transmit a discrete transponder code.
Be sure to activate your flight plan before crossing the ADIZ.
ICAO VFR flight plans must include in the transmitted line 18 "other information" section: DVFR/estimated United States ADIZ penetration at time (UTC) and estimated point of penetration (latitude/longitude or fix-radial-distance).
I would call my local FSDO, they can be found here:
http://www.faa.gov/about/office_org/field_offices/fsdo/
They will advice you as to how to proceed. Flying an airplane it is easy, just file a flight plan and stick to it and be in contact with the local ATC at all times. I have no idea how to do that with a UAV, but the FSDO will advice on how to proceed or if it is simply not possible legally.
I have had conversations with my local FSDO as I fly under the 333 exception, they have been helpful in clarifying some of the rules that are a bit unclear and even contradictory in some cases.
2016-6-29
