New Firmware for Phantom 3 Pro/Adv has been Released
jacmac64
dbostock and dewulf.harry and anyone else having issues with this firmware
The best thing to do is the reinstall Firmware v1.8.80 until DJI releases a new version to resolve this.
I don't know why they're not tell people to hold off on updating because this firmware update is causing to many problems.
2016-7-10
dbostock
Thanks jacmac64. Is it just a case of loading the v1.8.8 firmare on sd card and putting in p3 then turn p3 on for it to downgrade.  Same process as an upgrade?  Does anything need to be done with controller firmare.
My assumption is that there will be no fix for this issue in future firmare upgrades as DJI havent acknowledged this is a problem with firmare but hardware.  Ridiculous
2016-7-10
jacmac64
It's exactly the same, just put previous firmware on you sd card and it will install. This made my video transmission better but it's not 100% what it was before I installed the new release.
Now i don't even want to fly.
2016-7-10
dbostock
So ur getting further than 500m odd distance but cuts out still sometimes?
2016-7-10
DJI-Paladin
Flight distance : 2408 ft
dewulf.harry Posted at 2016-7-11 01:43
do we need to update the controller to?
The latest RC firmware version is 1.6.0. If your RC has bee updated to this version, you don't need to upgrade it again.
2016-7-10
dbostock
Thanks Paladin, How do I confirm that my RC has 1.6.0?
Also can you tell me does DJI have any plans of resolving this issue or has it not been recognized as a firmware issue?
2016-7-10
DJI-Paladin
dbostock Posted at 2016-7-11 10:20
Also can you tell me does DJI have any plan ...
When your mobile device is connecting to your RC (power on), you can enter the camera view and touch the icon on the right top.The firmware version is under General Settings——About.
2016-7-10
pdavidyoung
Just bought a P3A - (waiting for it to arrive) - should I update any of the firmware if it is required?  I just bricked my P2 so I am a little leery about doing any firmware updates.
2016-7-11
dbostock
If it was me, I would either leave firmware as is from box. Or upgrade controller to latest version and put v1.8.8 on P3. I did a test this morning after downgrading to this firmware and from what I can tell it has resolved my disconnection issues.. but DJI may recommend to upgrade to latest v1.9 version as they advise there is no problem with latest firmware.. its a hardware issue
2016-7-11
naudclick.infor
Flight distance : 400732 ft
Last dji go update is horrible! Lag on video back two seconds. Litchi otherwise have to use'm grounded. If the problems do not rule quickly because it lasted too long see myself obliged to part with my P3A could a Yuneec
2016-7-12
PG101
Flight distance : 2194390 ft
I've updated my P3P and I've noticed that filming in 2.7K gives a very soft image, all detail is smoothed out, other modes (1080, 3,8K and 4K) have plenty of detail.
What is going on with noise reduction? Also, the dark areas of videos shot in 3.8K have a slight red tint that is absent from all other video definitions. This is so weird.
2016-7-12
T-Rex
Flight distance : 966148 ft
Hi
I have a P3A; every thing was fine with fw 1.8.80. Then I updated to fw 1.9.60 and since then the video was unstable and the latency was about 3 to 5 second. I decided to downgrade to fw 1.8.80 but the upgrade failed
[00012067]========== remo-con disconnect. boot(15) ============
[00012125]Packet [C:\P3S_FW_V01.08.0080.bin] detected, card sn [0x6310088b].
[00012178]Packet upgrade start...
[00012230]Packet checking...
[00012287]Packet vlink 01.08.0080 <-> 01.07.0060.
[00012341]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 1).
[00012389]Done.
[00012445]Version checking[1]...
[00012521][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012599][03 06][00] v2.4.20.18 -> v2.4.14.5 need upgrade.
[00012663][04 00][00] v1.44.0.0 -> v1.44.0.0
[00012801][11 00][00] v1.8.0.0 -> v1.7.15.1
[00012893][12 00][00] v1.10.0.0 -> v1.10.0.0
[00012993][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013093][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013220][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017770][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017869][17 00][00] v1.1.1.7 -> v1.1.1.7
[00018008][17 01][00] v1.0.2.7 -> v1.0.2.7
[00018084][19 00][00] v255.255.255.254 -> v1.0.8.96
[00018140][01 00][00] v1.23.4920 -> v1.23.4920
[00018189][01 01][00] v1.23.4920 -> v1.23.4920
[00018247][09 00][00] v3.0.0.10 -> v3.0.0.10
[00018300]Done.
[00020461]Waiting for user confirm...
[00030510]Timeout, start upgrade automatically.
[00030613]Firmware upgrading[1]...
[00030884][03 06] Firmware upgrade start...
[00374845][03 06] Firmware upgrade finished successfully.
[00374894]Done.
[00374947]Version checking[2]...
[00375042][03 05][00] v34.2.0.9 -> v34.2.0.9
[00375122][03 06][05] v2.4.14.5 -> v2.4.14.5
[00375188][04 00][00] v1.44.0.0 -> v1.44.0.0
[00375322][11 00][00] v1.8.0.0 -> v1.7.15.1
[00375422][12 00][00] v1.10.0.0 -> v1.10.0.0
[00375530][12 01][00] v1.10.0.0 -> v1.10.0.0
[00375630][12 02][00] v1.10.0.0 -> v1.10.0.0
[00375738][12 03][00] v1.10.0.0 -> v1.10.0.0
[00408292][15 00][00] device not detected.
[00408393][17 00][00] v1.1.1.7 -> v1.1.1.7
[00408533][17 01][00] v1.0.2.7 -> v1.0.2.7
[00408608][19 00][00] v255.255.255.254 -> v1.0.8.96
[00408659][01 00][00] v1.23.4920 -> v1.23.4920
[00408716][01 01][00] v1.23.4920 -> v1.23.4920
[00408810][09 00][00] v3.0.0.10 -> v3.0.0.10
[00408862]Packet upgrade failed at version checking.
The online support told me I have to send it in for repair.
Any experience on that error " [00408292][15 00][00] device not detected." ?
Thanks.
2016-7-12
DJI-Paladin
T-Rex Posted at 2016-7-13 04:28
Hi
I have a P3A; every thing was fine with fw 1.8.80. Then I updated to fw 1.9.60 and since then th ...
There is a hardware error in the image transmission module and it is recommended to send it in for repairing. Here is the contact information: 联系欧洲.JPG
2016-7-12
T-Rex
I think it is mandatory more than a raccomandation. Now I can't fly it.
The problem is that the product is two months old only and repairing service is needed without any crash or strange use. Anyway I hope at least it will be a warranty repair. Ciao
2016-7-12
Zippy P3A
I am puzzled after my upgrade as to the results.  Here is what I got...     AND I FORMATTED THE SD FIRST
At the top of the list...
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
========== 2016.01.31 10:49:07 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.01.31 11:03:20 =====================
Result: Abort.
>>>>>>>Then the same repeats about 30-4- times, then I get this...  <<<<<<<
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3S_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
>>>>>>>>>>>And below that is...         about 30-40- times<<<<<<<<<
========== 2016.06.14 17:24:06 =====================
Result: Abort.
========== 2016.06.14 17:25:22 =====================
Result: Abort.
And then, finally...
========== 2014.01.01 00:00:10 remo-con disconnect======
Result: Abort.
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Upgrading ...
Result: Failed.
SO, IS MY AIRCRAFT UPGRADED OR NOT?  FIRST IT SAYS IT IS, THEN IT ISN'T.  WHERE DO I GO FROM HERE?
2016-7-13
Zippy P3A
Upgrading ...
Result: Abort.
Result: Abort.
Then the same repeats about 30-4- times, then I get this...========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
2016-7-13
Zippy P3A
Upgrading ...
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Upgrading ...
Upgrading ...
Result: Failed.
2016-7-13
m_s_karimi2000
Iran
Hi everyone
I have a serious problem. when I update Dji app and firmware to the latest (1.9.60) everything is ok. but just when I press Record button on RC I have delay on my tablet!
who know how can I solve this?
can I "downgrade" firmware to 1.3.20? is it possible?  I had real live view -no delay-
2016-7-13
Chuck1906
Flight distance : 3574003 ft
I haven't updated my firmware since 1.5 which I am currently still using. If I want to update, do I have to go in order of updates or can I just go directly to the most recent update?
2016-7-14
braddoll13
Flight distance : 42346 ft
Ive been happy. I know that don't fix others concerns.  But i to experience video feedback problem at times, my complaint.  Remember there is a sequence to start up.  Remote, no tab or phone plugged in, than craft, than,  than plug, or turn on dji... hope it helps
2016-7-14
braddoll13
I made it only 3300 ft. Not quite what it says it will do, but my video is what started cutting out, rc signal good. So i do hope they fix with a new update.. but i am happy.  3300 ft was out there!
2016-7-14
buzzcbr
Flight distance : 316545 ft
FAS1 Posted at 2016-6-13 13:49
If it works for you, then fly it. Updates are only 'suggestions'. I am still on 1.4.6 and have no de ...
Im with you on this, stuck at 1.4.6., when they upgraded the camera, and the 'fly around' section, with no having to 'log in and request permission to fly' bullshit.
So im never gonna upgrade, and when this thing eventually crashes, I wont buy DJI, I'll get something else that doesnt have the 'request to fly' built in.
The geofence was more than enough restriction. DJI have just made their product less desirable to me.
2016-7-14
ELISEU
I am testing my Phantom 3 Pro on a tablet android 4.4, with version 2.8.2 . Are giving total loss of signal.{:4_142:}
2016-7-14
imagesbyjas
Flight distance : 286198 ft
DJI-Paladin Posted at 2016-7-13 10:40
There is a hardware error in the image transmission module and it is recommended to send it in for ...
Paladan..
So a very serious question here.  It has been noted in quite a number of posts of the image transmission module in the gimbal going bad after a fw upgrade.  Donnie has highly recommended the procedure of making sure the RC if powered OFF when updating the aircraft, but here is the question..  T-Rex was fine he indicated before applying 1.9.. What is it that can cause that Image Transmission Module to be so sensitive to failure during fw upgrades, and what is the absolute best way to avoid it??  This is not the first time we've heard this issue..  :-(
2016-7-14
DJI-Paladin
imagesbyjas Posted at 2016-7-15 08:40
Paladan..
So a very serious question here.  It has been noted in quite a number of posts of the i ...
I can understand your feeling but it is a rare event. If you meet this kind of issue, it is recommended to contact our support and send it in for repairing. Thank you for your understanding.
2016-7-14
Insanity
I updated to the new firmware right after the release, and have had nothing but problems. On one occasion, my drone decided to land in a very bad spot. Fortunately I was able to chase it down and override the landing such that it was a controlled landing in a better spot. The biggest problem for me is the "iffy" reception quality. Sometimes it is fine out to 2000' or more, sometimes 200' I lose communication. Very uncool...
2016-7-14
DJI-Paladin
Insanity Posted at 2016-7-15 11:53
I updated to the new firmware right after the release, and have had nothing but problems. On one occ ...
Keep your eyes on the image transmission quality and adjust the RC and antenna if necessary during the flight:
2016-7-14
imagesbyjas
DJI-Paladin Posted at 2016-7-15 10:01
I can understand your feeling but it is a rare event. If you meet this kind of issue, it is recomm ...
Paladin..
Agreed, I'm sure, compared to the number of successful upgrades, but there is seemingly a correlation associated to these Video Transmission Modules and Firmware Upgrades.  Personally, I follow the advice of upgrading aircraft first (via micro SD) with RC powered off, then do RC upgrades with Aircraft off, then any battery updates...  That said, I'm still on 1.8.80 and 2.8.1 and flying without issue.  Waiting till GEO settles out a bit before moving..  I guess what I'm asking is if DJI sees these occasions as a chance to make sure the upgrade sequence is readily known and hopefullly followed, but also if they have uncovered a "reason" why on certain occasions having the RC on while upgrading the aircraft seems to go after that module.  Again, we've seen it referenced in these forums a fair number of times, so there is some connection.. (it would seem).
Thanks for the reply..
2016-7-15
UCLABruins
Flight distance : 488904 ft
I'm on 1.8.80 with DJI Go on 2.8.4 with no issues. Distance has been great with perfect video download transmission. There is no reason to upgrade to the latest firmware if your bird is working unless the firmware offers significant feature improvements.
2016-7-15
Bobby8
Flight distance : 84774 ft
Bahamas
mav5257 Posted at 2016-6-13 08:32
Hello, sorry for the stupid question but i'm novice:
I can not update the firmware for a few days . ...
You can still fly safe
2016-7-15
Bobby8
Bahamas
Yes you can fly safe
2016-7-15
Bobby8
Bahamas
2016-7-15
jacmac64
Amazing
All these video transmission issues after this latest firmware update and they still won't admit that there's a problem with it.
Their answer is sending it in for repair. How about removing it and fixing the problem with the firmware?
2016-7-16
T-Rex
DJI-Paladin Posted at 2016-7-15 04:01
I contacted  the dji support and sent the drone in. So far the service is good and they are also covering the shipping cost. We will see how long the repairing process will take.
Then, I would like to understand more about this video transmission module hw, the video was slow and unstable before I discovered this error. The upgrade to 1.9.60 went smooth no error at all; the error come up when I tried to downgrade to the previous version trying to solve the video problems. To me it looks like the 1.9.60 could have damaged the hw but the system realize that only in the next firmware update?
Thanks for the support!
2016-7-16
T-Rex
2016-7-16
imagesbyjas
T-Rex Posted at 2016-7-16 21:24
I contacted  the dji support and sent the drone in. So far the service is good and they are also c ...
T-Rex..
You may have seen my reply earlier.  Did you happen to have the RC powered ON when doing the firmware upgrade?  It is something that has been pointed out in the past as a possible cause of Video Transmission Modules going bad..  Just curious...
2016-7-16
T-Rex
imagesbyjas Posted at 2016-7-16 16:14
T-Rex..
You may have seen my reply earlier.  Did you happen to have the RC powered ON when doing  ...
Imagesbyjas
No I am sure I followed the procedure: formatted sd card, just bin file on it and then power on only the aircraft. I am a newbie but I did already 2 upgrade successfully but the last one caused some video problems (lag and unstable), when I tried to go back to previous firmware (with RC off) the error showed up. In any case if there is the suspect that can be one possible cause of the damage, I think Dji should introduce something that inhibit the upgrade process when RC signal is detected.
2016-7-16
mrbill
Flight distance : 717100 ft
rlp0464 Posted at 2016-7-8 04:24
So i chatted with DJI, and solved the problem.  Thanks DJI!
Are you going to tell us what happened?
2016-7-16
T-Rex
mrbill Posted at 2016-7-16 18:19
firmware update failed and module 15 not detected in the upgrade log file. The drone seems fine but huge video lag and video transmission unstable exactly the same as before I tried to go back to few 1.8.80 from 1.9.60.
2016-7-16
mrbill
So it's not really problem fixed then?
2016-7-16
