P3ADV Video Lag / green screen on app
1931 23 2016-7-17
ahmet
Flight distance : 984852 ft
Turkey
Hello
Since the latest firmware update im having problems with image/video transfer between my drone and app.
Its like 5-6 sec delay. ( exp. i move my drone and the view that drone is looking which i should see on my iphone comes like 5-6 later)
So i cant fly long distances. I dont see where i am going.
All other functions are working correctly. I command my drone perfectly. Land on/off works perfect. etc... everything but the green screen and video lag
Anyone having the same problem? Is there anything i should do ?
I do want to say that these all happened after the latest firmware.!
Phantom 3 Advanced
Drone / RC / All Batteries are using latest versions
Iphone 6s Plus
Latest Dji go app
2016-7-17
DJI-Paladin
Flight distance : 2408 ft
Hello ahmet, have you tried to enable the "hardware decoding" option and use different lightning cables? The hardware decoding option can be found in General Settings.
2016-7-18
Ahmet67
Turkey
DJI-Paladin Posted at 2016-7-18 11:36
Hello ahmet, have you tried to enable the "hardware decoding" option and use different lightning cab ...
Yes, Ive that tried it with and without "hardware decoding" option. And also used different lightning cable (all orginal)
2016-7-18
DJI-Paladin
Ahmet67 Posted at 2016-7-18 19:53
Yes, Ive that tried it with and without "hardware decoding" option. And also used different lightn ...
Does the same issue come up with different mobile device?
2016-7-18
ahmet
Turkey
DJI-Paladin Posted at 2016-7-19 05:07
Yes. Ive tried that with more then 2 different devices (mobile phone/tablet) (samsung and apple)
I would like to say that green screen doesnt come up so often but the delay ive mentioned above happens like  9 of 10 times.( ill record a video asap and upload here about what im talking about)
Note: It was all fine before the last update, i had no problems..
2016-7-18
DJI-H.C
ahmet Posted at 2016-7-19 03:27
Hi, you can find the previous firmware you're using here http://www.dji.com/product/phantom-3-adv/info#downloads
Unzip it and put the bin file into your SD card, put the SD card into your drone, and power on the drone. Then it will downgrade itself to the previous firmware.
2016-7-18
DJI-Paladin
ahmet Posted at 2016-7-19 15:27
What kind of devices have you tested? Are they the devices in the recommended list? 兼容列表.JPG
2016-7-18
ahmet
Turkey
DJI-H.C Posted at 2016-7-19 10:34
Hi, you can find the previous firmware you're using here http://www.dji.com/product/phantom-3-adv/ ...
Hello
I did that downgrade before but i had the same problem. At the moment im uploading a video of my problem it will be on comment list soon sir.
2016-7-19
Ahmet67
Turkey
DJI-Paladin Posted at 2016-7-19 10:38
iphone 6s plus, 64gb
ipad air 2, 64 gb
samsung s6, 32 gb
all updated
Here i uploaded the video of my problem
Please pay attention on both device screen and the drone's cam.
while the camera is moving i should see the instantaneous display on the mobile device but it lags.
2016-7-19
DJI-Paladin
Ahmet67 Posted at 2016-7-19 16:45
ipad air 2, 64 gb
samsung s6, 32 gb
What's the image transmission condition at this time? A screenshot will be appreciated.Also, is it the original lightning cable? Have you tried to clean the cache in the app?
2016-7-19
Ahmet67
Turkey
Yes my cable is orginal, i bought it from apple store
after your suggest ive tried cleaning cache, but its still the same
2016-7-19
ahmet
Turkey
DJI-Paladin Posted at 2016-7-19 11:49
What's the image transmission condition at this time? A screenshot will be appreciated.Also, is it  ...
Ive attached the screen shots
2016-7-19
DJI-Paladin
ahmet Posted at 2016-7-19 17:39
Please touch the HD icon and make a screenshot like this: 信道.PNG
2016-7-19
Ahmet67
Turkey
DJI-Paladin Posted at 2016-7-19 12:41
2016-7-19
DJI-Paladin
Have you tried it outside and select a custom channel with less noise? Lower the image transmission quality if necessary.
2016-7-19
Snowwolfwarrior
Flight distance : 1064780 ft
Lots of people getting same problem, can I just ask you to go do same test away from civilisation, in a field
2016-7-19
Ahmet67
Turkey
DJI-Paladin Posted at 2016-7-19 13:03
Have you tried it outside and select a custom channel with less noise? Lower the image transmissio ...
yes ive tried it outside
also with a custom channel
just took photos inside just for forum conversations
im getting tried of this bug or something.. i want to fly
2016-7-19
DJI-Paladin
Ahmet67 Posted at 2016-7-19 18:06
Sorry for the inconvenience. It is recommended to contact support@dji.com and send it in for diagnosis because it is probably a hardware issue.Hope you can understand.
2016-7-19
Ahmet67
Turkey
DJI-Paladin Posted at 2016-7-19 13:24
Sorry for the inconvenience. It is recommended to contact  and send it in for diagnosis because it  ...
well, what i dont undestand is, it was all fine before latest firmware and after that i didnt drop it or fall. its really wierd. it just happened with update :/
2016-7-19
DJI-Paladin
Ahmet67 Posted at 2016-7-19 18:40
well, what i dont undestand is, it was all fine before latest firmware and after that i didnt drop ...
I can understand your feeling but currently it would be better to send it in for diagnosis.
2016-7-19
thomasneumann10
Im having the same issue besides My lag is 5-10 seconds it is not usable. It is brand new and only flown 2-4 times! never crashed or mistreated, multiple devices, every setting possible, firmware as well. 4 different cables.
I got in contact with dji support 2 days ago but they haven't mentioned a possible solution.
2016-7-19
Ahmet67
Turkey
thomasneumann10 Posted at 2016-7-19 15:57
Im having the same issue besides My lag is 5-10 seconds it is not usable. It is brand new and only f ...
Im 100% sure, its all about the firmware and app!!! I will wait for new firmware update before i send my p3a to diagnosis
2016-7-19
thomasneumann10
Ahmet67 Posted at 2016-7-19 10:15
Im 100% sure, its all about the firmware and app!!! I will wait for new firmware update before i s ...
Im hoping so but the only time i flown this was right when i got iit, there have been i think two updates.firmares where the problem remained.
DJI support doesn't give any hint that it might be the app. well see tho
2016-7-19
ahmet
Turkey
thomasneumann10 Posted at 2016-7-19 18:31
Im hoping so but the only time i flown this was right when i got iit, there have been i think two  ...
yes there have been 2 updates.
well you are using a brandnew 1 which shows its not about the hardware
im happy about that tho
2016-7-19
