Battery Cell Damage MidFlight
1251 9 2016-8-3
aididhaiqal
Flight distance : 1132822 ft
Malaysia
Hello guys,So im in process trying to get new Inspire 1 Raw Drone because my drone was crash.It happend when it was far away from me during the event and when i try to go home...Signal lost and it never connected back...I try to run away to better open area and yes i get signal..Full bar image singal only but no image...This happend for few time...There is no RTH Event happend.So my question is,Did i need to search the drone in order to get replacement or DJI Go APP can help?
2016-8-3
Rinzler
Not sure what this has to do with a battery issue. This sounds like you went out of LOS and something interference wise took out your drone or it ran into something and you lost it and have not recovered it. The Go app should be able to tell you last known location of it. It also sounds like the RTH function was turned off. I know with mine just looking at it wrong causes it to enter RTH. I would check the app and look at your flight log. Then go search that area for it. Cant repair / warranty something if it does not exist.
2016-8-3
aididhaiqal
Malaysia
Good news,I use 3RD Party GO App reader and i found out my drone is going to landing far away from home point...And it survive!Now i need to calibrate the battery and make a checklist for checking battery volt each flight..
2016-8-3
Donnie
Flight distance : 3636782 ft
aididhaiqal Posted at 2016-8-3 08:17
Good news,I use 3RD Party GO App reader and i found out my drone is going to landing far away from h ...
Before you go any further , consider purchasing a GPS locator such as the Trackimo.  Also until you get more flight time in , keep the aircraft close by. be sure to have the RTH settings set to Return to home and not Hover or land.  I think lack of flight time and not familiar with the aircraft system  caused this , next time you may not get so lucky.
donnie
2016-8-3
Rinzler
Donnie Posted at 2016-8-3 10:25
Before you go any further , consider purchasing a GPS locator such as the Trackimo.  also until you ...
Yeah as Donnie said. LOS until you know what you are doing or use a spotter.
2016-8-3
DJI-Jamie
Flight distance : 112405 ft
aididhaiqal Posted at 2016-8-3 21:17
It's good to hear you were able to recover your unit. As others have said, you should remain withing line of sight while you are still learning the aircraft.
2016-8-3
aididhaiqal
Malaysia
Rinzler Posted at 2016-8-3 22:30
No,The drone is in might Sight
2016-8-3
aididhaiqal
Malaysia
2016-8-3
aididhaiqal
Malaysia
DJI-Jamie Posted at 2016-8-4 03:37
It's good to hear you were able to recover your unit. As others have said, you should remain withi ...
Hey Jamie,Where can i fully read the flight log that i extract from the drone?
2016-8-3
DJI-Jamie
aididhaiqal Posted at 2016-8-4 06:42
If you're looking to read the .DAT files from the aircraft, customers have used programs like HealthyDrones or ones to that effect.
2016-8-3
