Drone will not enter travel mode
1696 12 2016-8-11
UnSean1
My new updated Inspire will not enter travel mode from go app or manually.
Any help thanks.
Sean
2016-8-11
Cougar1
Flight distance : 924393 ft
Update the RC to newest firmware, helped a friend with the same issue. After updating Firmware all worked fine.
2016-8-11
UnSean1
Cougar1 Posted at 2016-8-11 16:20
Update the RC to newest firmware, helped a friend with the same issue. After updating Firmware all w ...
Thanks, but using latest firmware in everything
2016-8-11
Cougar1
So  you are using firmware 1.7.40 on the remote controller? My friend had the same issue where landing gear would not go in travel mode using either the app or the switch on the RC. After updating the RC it all worked.
2016-8-11
DJI-Jamie
Flight distance : 112405 ft
UnSean1 Posted at 2016-8-11 23:22
Do you have the VPS enabled? Are you trying to do this on a smooth flat surface? Can you connect to the DJI Go app, get camera view, and confrim what firmware versions you have on your unit?
2016-8-11
UnSean1
DJI-Jamie Posted at 2016-8-11 17:38
Do you have the VPS enabled? Are you trying to do this on a smooth flat surface? Can you connect t ...
Yes, all latest firmware drone, rc, camera, etc I got it to work now by sitting it on the case, it does not like my carpet. thanks for the help guys.
2016-8-11
DJI-Jamie
UnSean1 Posted at 2016-8-12 04:07
Yes, all latest firmware drone, rc, camera, etc I got it to work now by sitting it on the case, it ...
Good to hear you were able to resolve the issue. Let us know if you have any additional questions or concerns.
2016-8-11
taborproduction
First one wouldn't leave travel mode. Replacement doesn't work either.
2016-8-13
DJI-Jamie
taborproduction Posted at 2016-8-14 03:04
Could you happen to elaborate? Did you replace the aircraft or the RC? What troubleshooting steps have you done thus far?
2016-8-15
fans1c7737b1
Flight distance : 30476 ft
This is just a quick thank you to those who shared the same issue and those who offered solutions.  I had the same problem on a one week old Inspire 1 v2.0.  My issue turned out to be the surface I was on.  Seems Inspire likes dark and smooth surfaces.  No grass or carpet.
Cheers
2016-11-15
Enal
Flight distance : 27241 ft
Suddenly after a flight today mine won't enter travel mode. I thought my case suddenly grew bigger! Haha
I did notice that during the flight that the altitude being called out was -2 at 3ft and then -4 at landing.
I'm not sure how that happened, but I'll be looking at it closer tonight and hopefully solve the issue.
2016-12-1
DJI-Jamie
Enal Posted at 2016-12-2 06:44
Suddenly after a flight today mine won't enter travel mode. I thought my case suddenly grew bigger!  ...
You may need to check the VPS sensors to see if they need to be cleaned. In addition, what kind of surface would you attempting to switch to travel mode on? An IMU calibration can help with the altitude reading as well.
2016-12-1
Enal
I figured out my problem... It's the hard surface issue!
Meaning that I was holding the Inspire in my hand about 3ft off the ground when I put it into Travel Mode instead of sitting it on the top of the case or hard flat surface.
Last night I put a battery in it and put it into Fly Mode and back into Travel Mode and it was fine...
Thanks for the response!
2016-12-2
