PIP using HDMI and AV port?
7687 11 2016-8-10
chris
Flight distance : 250125 ft
My setup is a M600 with MX gimbal.  I'm wondering if it's possible to connect my DSLR to the LB "HDMI" port cable, and a GoPro or similar FPV camera's Analog AV output into the "AV" port on the LB2, and run PIP.
I need to be able to have FPV for the M600, while my second camera opperator tilts and zooms with the MX gimbal. I'd rather not have to add a Connex for my gimbal feed, and run the gopro into the lightbridge.
Is the PIP feature only capable on the Zenmuse gimbals since they plug into the LB2's "Gimbal" port instead of the other two?
Can the G- and G+ be used as analog inputs on the "Gimbal" port if need be?
2016-8-10
DJI-Jamie
Flight distance : 112405 ft
You can follow the diagram for PIP on page 64 of the M600 manual:
https://dl.djicdn.com/downloads/ ... 9%8B%E5%86%8C-v1.0+(en).pdf
2016-8-11
Quadrocopter
So it would appear, by the explanation on page 64, that this is indeed possible. That being said, I will give it a try when the AV port cable arrives and I can solder a Go-Pro or other FPV cam video signal cable to it.
Thanks, and viewers of this thread, stay tuned.
-Chris
2016-8-11
DJI-Jamie
Quadrocopter Posted at 2016-8-12 04:52
So it would appear, by the explanation on page 64, that this is indeed possible. That being said, I  ...
Please let me know if you run into any additional questions or concerns once you're able to acquire the cable.
2016-8-11
Quadrocopter
Thanks, I will definitely post replies with pictures and possibly a video of this feature. Having a separate video feed for pilot and cam-op is key.
2016-8-11
DJI-Jamie
Quadrocopter Posted at 2016-8-12 05:21
Thanks, I will definitely post replies with pictures and possibly a video of this feature. Having a  ...
Looking forward to it.
2016-8-12
Hammer_Time
Flight distance : 466106 ft
Any luck yet?
2017-5-12
mikes1
Flight distance : 1740699 ft
Can anyone tell me were to get the AV connector so I can hook up an analog video to the LB2 port? I have been using HDMI but would like to try the AV output. Part number or a link would be great.
2017-7-11
Quadrocopter
mikes1 Posted at 2017-7-11 06:53
It's the second to the last cable in the picture:
https://store.dji.com/product/lightbridge-2-cables
2017-7-11
DownDraft
Flight distance : 2059534 ft
I ordered this from Digikey, using the long wires made up my cable  for the AV input
The only problem I am having is switching between cameras.  Either one works or the other.
www.digikey.com
455-1593-ND
GHR-03V-S         CONN GH HOUSING 3POS 1.25MM                 0.07560         $3.78
455-1606-1-ND
SSHL-002T-P0.2         CONN TERMINAL GH 30-26 AWG          0.06490         $6.49
455-3074-ND
AGHGH28K305         JUMPER SSHL-002T-P0.2 X2 12"            0.39000         $19.50
2018-9-10
John_0
I think the AV connector on LB2 is:
JST SM03B-GHS-TB
It is a three pin connector that is very hard to find when searching for LB2 connectors.  Four pin versions are much easier to find, so I took a 4-pin version and shaved it down to 3-pin version using a Dremel tool (very carefully - it's easy to shave too much).  I currently use that shaved-down version to connect the LB2 to a RunCam camera and it works great.   My suggestion on the part number of the AV connector (JST SM03B-GHS-TB) is only an educated guess based on the confirmed part number of the 4-pin version, JST SM04B-GHS-TB, which I found on the Gremsy gimbal website.  Gremsy sells cables for the M600 and identifies the part numbers for the connectors.
2021-6-5
rogiervdheide
Liechtenstein
This is the right connector (series). Look for the 3-pin version.
https://www.jst-mfg.com/product/pdf/eng/eGH.pdf
2022-9-22
