Will not connect to Naza Assistant
3732 26 2016-8-18
radiodj3
I have tried everything and my drone refuses to connect to the software. any suggestions would be greatly appeciated
2016-8-18
DJI-Paladin
Flight distance : 2408 ft
Hello radiodj3,please make sure the driver has been installed successfully
http://www.dji.com/product/phantom/info
2016-8-18
DJI-H.C
Hi, when you connect your drone to your PC, does the PC makes any beeping sound, or pop up something, or show a new Drive?  That makes at least the physical connection is fine.
2016-8-18
radiodj3
I have repeatedly installed the drivers to no avail, as for a pop up or a sound alerting or showing another virtual drive...no
2016-8-19
RATTYDUDE77
Flight distance : 2917 ft
does the green light on the back of the quad go off
2016-8-20
radiodj3
RATTYDUDE77 Posted at 2016-8-20 07:08
yes it does...infact there all the lights go off
2016-8-20
RATTYDUDE77
does it beep or make the start up noise when plugging the quad in
2016-8-20
radiodj3
RATTYDUDE77 Posted at 2016-8-20 16:57
when i plug the battery in, yes
2016-8-20
RATTYDUDE77
what does it do when you plug the USB to the computer to the quadcopter
2016-8-21
radiodj3
RATTYDUDE77 Posted at 2016-8-21 12:57
all the lights go out, beyond that...nothing on drone or computer
2016-8-21
DJI-Jamie
Flight distance : 112405 ft
radiodj3@yahoo. Posted at 2016-8-22 03:57
What operating system are you using?
2016-8-21
radiodj3
DJI-Jamie Posted at 2016-8-21 17:16
Windows 10
2016-8-22
DJI-Jamie
Try to reinstall the DJI WinDriver in compatibility mode. When choosing a previous working OS in this mode, use Windows XP. Please let me know if the issue persists.
2016-8-22
radiodj3
DJI-Jamie Posted at 2016-8-22 17:14
Try to reinstall the DJI WinDriver in compatibility mode. When choosing a previous working OS in t ...
ran everything in as you suggested and still nothing
2016-8-23
DJI-Jamie
radiodj3@yahoo. Posted at 2016-8-24 00:01
Since you are getting some sort of indication that a device was connected, then that means that there is some sort of setting on the computer that it's keeping it from recognizing. Based on the information provided, could you please confirm if your presumed set up is a Phantom 1 with the Naza M Assistant? Have you tried a different computer? Was this ever working for you before, or is this your first time connecting?
2016-8-23
radiodj3
DJI-Jamie Posted at 2016-8-23 11:54
Since you are getting some sort of indication that a device was connected, then that means that the ...
i have tried another computer, i experienced the same issue. i bought this drone from a friend who said he could never get it to connect either. as of now, i have never gotten it to connect as well
2016-8-24
DJI-Jamie
radiodj3@yahoo. Posted at 2016-8-24 23:10
i have tried another computer, i experienced the same issue. i bought this drone from a friend who ...
Was the other computer a Windows 10 as well or a different operating system? Do you happen to run the Assistant Software as an administrator?
2016-8-24
radiodj3
DJI-Jamie Posted at 2016-8-24 10:56
Was the other computer a Windows 10 as well or a different operating system? Do you happen to run  ...
other computer is windows 10...in fact all my computers are windows 10. yes i ran as admin
2016-8-24
DJI-Jamie
radiodj3@yahoo. Posted at 2016-8-25 02:36
There is one last thing I would like to check in regards to compatibility mode. Would you troubleshoot compatibility from the .EXE file and hit "test" before saving? One thing that can be overlooked is that when you select "test", a security icon would appear on the task bar that needs to finish authorizing the compatibility mode. It would be preferred to do this on both the WinDriver and the Assistant, I apologize if I did not make it clear before.
2016-8-24
radiodj3
DJI-Jamie Posted at 2016-8-24 17:48
There is one last thing I would like to check in regards to compatibility mode. Would you troubles ...
i did as you suggested, still nothing
2016-8-25
radiodj3
also have noticed that when i start naza asst, i get a splash screen with a progress bar....this will stay like this until i hit "skip"
2016-8-25
DJI-Jamie
radiodj3@yahoo. Posted at 2016-8-26 03:17
also have noticed that when i start naza asst, i get a splash screen with a progress bar....this wil ...
Having to skip is normal. If it's not working on Windows 10, the only thing that can be done to rule out a computer issue is to try a different operating system. If you're not able to borrow a different computer, then the only other option is to have the unit in to the North American Support Center for further diagnostics. One can only hit their head against the proverbial wall for so long.
2016-8-25
radiodj3
DJI-Jamie Posted at 2016-8-25 17:25
Having to skip is normal. If it's not working on Windows 10, the only thing that can be done to rul ...
i found an old Gateway machine in the garage....with windows XP on it....installed software, hooked up drone....naza assistant worked perfectly..i kinda figured it was a compatibility issue. Thank you for all your help!!!
2016-8-26
DJI-Jamie
radiodj3@yahoo. Posted at 2016-8-27 03:15
i found an old Gateway machine in the garage....with windows XP on it....installed software, hooke ...
I'm glad to hear you were able to get it up and running on a computer. It may take some tinkering, but you can try to get it to work with Windows 10 for the future. Since compatibility mode did not seem to do the trick, you can try to look at your security settings since not a lot of current domestic computers like Chinese programs. At least you do have a system that can run the program.
2016-8-26
radiodj3
DJI-Jamie Posted at 2016-8-26 15:22
I'm glad to hear you were able to get it up and running on a computer. It may take some tinkering, ...
Again, i really appreciate all the help and input!
2016-8-26
nikogto
Flight distance : 15965 ft
You lucked out. I don't have an old pc to try. My windows 10 won't work. I have no issues with my P1, just wanted to be able to change some settings. Have a P4 now, so the P1 is rarely used.
2016-9-9
jdwafc
see this i put up on other forum
http://www.phantompilots.com/thr ... o-windows-10.77162/
2016-10-12
