3330ft/1015m in CE mode?? (P34K)
1590 11 2016-8-25
Mariuss
Flight distance : 2480515 ft
So today i went a little further than expected. Current range of the P34K is 500m in CE mode. I got 1015m, then got scared and flew back. I might just have gone even further if i would dare. Conditions were about optimal except for the wind. Any ideas why/how this happend?
If you have lightbridge and dont care about this kinda range, heres some unedited footage of the flight!
2016-8-25
There is no rule that says your aircraft can only go 500 Metres, all thos figures are estimates, if it goes further then fine. Don't sweat it, it should always return home.
2016-8-25
Aardvark
Flight distance : 384432 ft
Lovely Sunset @ 0:40. I'm curious though as to why only 720P on utube. Was this shot in 4k ?
2016-8-26
michaelfinney_h
Nice video. Good music
2016-8-26
Mariuss
Aardvark Posted at 2016-8-26 11:03
Hi! This was shot in 1280x720p 24fps. I totally forgot to set it to 1920x1080p which is the max of my screen card on this computer. Cant post process 4K yet but considering an upgrade as it's the future!
2016-8-26
Mariuss
Thanks Michael! This was done in 5 minutes so wasn't really more than a sequel of yesterdays flight as it was a range test. But had to snap the sunset!
2016-8-26
Mariuss
Geebax Posted at 2016-8-26 02:54
There is no rule that says your aircraft can only go 500 Metres, all thos figures are estimates, if  ...
So your'e saying that 27dbm and 20dbm doesn't differ in distance? Or that CE-limitations is not to be bothered with?
2016-8-26
darrin
Flight distance : 1004731 ft
just took my P3S to 7000' out before turning back..I do have the argtec antenna on RC and was in Alaska...so minimal interference.. Seemed I could have gone further that was the range of the video signal..I started 4000' the other direction.  So 11k' flight makes me pretty happy!!
2016-8-26
Mariuss
darrin@proimage Posted at 2016-8-26 18:12
just took my P3S to 7000' out before turning back..I do have the argtec antenna on RC and was in Ala ...
Wow thats a pretty decent distance! Dont think i can fit the argtek on the 4K controller tho!
2016-8-26
Mariuss Posted at 2016-8-26 23:40
So your'e saying that 27dbm and 20dbm doesn't differ in distance? Or that CE-limitations is not to ...
No. Reading my post I don't think that comes close to what I said. Under the conditions of unobstructed ground and zero competing radio signals, you can achieve the range you got and more.
2016-8-26
mdh317
Mariuss Posted at 2016-8-27 03:42
You may consider the DBS mod then. I just installed it on my P3 4k. A little pricier though. You are getting alot more distance stock in ce mode then i can get with mine with the dbs mod in fcc mode. Im only maxing out at around 600m before RTH kicks in. I am in a pretty dense residential area but still figured i could get to 800-900 meters.
2016-8-27
Mariuss
mdh317 Posted at 2016-8-28 02:43
You may consider the DBS mod then. I just installed it on my P3 4k. A little pricier though. You ar ...
Thanks! Have you ever tested the range in an open area?
2016-8-28
