P2 Vision flashing red lights and beeping
4250 10 2014-12-28
deanadamedge
Hello all!
Does anyone know how I can stop the red flashing lights and constant beeping coming from my P2 Vision when I start it up? There's no connection to the remote and all software is current...?
2014-12-28
DJI-Autumn
China
Calibrate your RC then try again
2014-12-29
deanadamedge
My mac won't connect to the rc even after I installed the app?
2014-12-29
Eirlink
Are you using the correct assistant ?
2014-12-29
deanadamedge.me
I fixed it now...many thanks...
2015-2-11
m.friedl
Flight distance : 3 ft
Austria
Would be great to write how you fixed it to share your Experience
2015-2-12
DRONEGALLERY
Iceland
deanadamedge.me how did you fix the problem of red flashing light and beep, couse I have same problem. hope your response...
2015-2-27
francall
Malta
I had the same problem which happened when I tried to use PT2 version 3.8 to upgrade the firmware and it failed mid-way.   I then used PT2 version 3.6, re-applied the firmware upgrades and the red flashing lights/bleeping sound went away.
2015-5-29
elbicho
   Have done all the things listed above several times but they don't work.
Today I received a new central controller and installed but the same thing.
Beeping and it appears to be constant alternating left/right/left/right front lights.
Don't know what to try next.  Are you also talking about the FRONT lights?
Mine goes all the way through completion and get GPS green blinking on the rear
two lights but the front ones blink in sync and then later they go to alternating right/left
right/left.  A dealer told me that was because of no GPS data but I don't think so.
GPS status is indicated on the rear lights.
2015-6-19
pb05life
elbicho@comcast Posted at 2015-6-20 11:18
Today I received a new  ...
what colors are they blinking, if it is yellow / red that is compass calibration
2015-6-21
roy
If your still getting beeps , it's normally due to incomplete upgrade or corrupted software. You may want to try another upgrade using a different USB cable. See if that corrects the problem. If you upgrade one the upgrade all so they are all up to date.
2015-6-24
