ScottGunn
I was wondering, when flying it there was a pretty good breeze. I have about 1 minute of video of the flight taken on a friends cell phone. Unfortunately it was right at takeoff, but the video shows me taking off and hovering at about ten feet. I stopped and showed him how the Inspire was holding position without any controller inputs, it was obviously at an angle against the wind direction with my hands off the controller. I was wondering, would the aircraft show stick inputs while it was automatically doing corrections to hold position even if there were no manual stick inputs?
What I'm saying is that if while I was hovering before it lost power, if it had to correct itself for the wind automatically in the same direction as if I was doing it manually with the controller and it translated that into the down stick and inward like the CSC on/off command would it shut down the power?
Back when I flew Nitro 3d helis, the auto corrections made by the gyro translated into controller trim adjustment "bursts" sent out to the servos by the gyroscope. The adjustments were only like a millisecond. I am not totally sure how the electronics in this aircraft communicate with each other, but if they use the same concept the aircraft could easily translate auto adjustments as the trim on the sticks, which is basically the same thing as stick inputs...
If you combine that with the fact that I was flying in beginner mode, which drastically reduces the reaction of the aircraft per distance the stick travels, and you could easily get to 100% stick travel in the appropriate position for a simple auto-correction.
