MD_Icarus
Maybe guys be a little more patient.
Maybe DJI is implementing my suggestion, which will transform the P4 into the "Range Champ" and "Superb video transmission Master" so they may need a few more days.
Here is my original suggestion:
1. Please change the P4 firmware to allow us to set the streaming video to 4 mbps and Auto. Right now the Auto setting, which is the safest setting to fly, works only at the higher mbps rate. If we can set it to a lower rate, then many of the streaming video pixelation, as well as, streaming video range issue will go away.
2. Please improve the HD channel hoping. In hundreds of hours flying my P4, the channel hoped to another channel in flight only 3 times! And it did not hop in cases when I lost the HD signal. This should be a simple change for the developers. Once the power level drops to some critical level, then they should keep changing the channel until the signal improves.
2a) Please add the channel in your DJI GO logs. I can only see the channel in litchi logs. But the app does not control the channel once in flight; it is the P4 firmware. |
