Da Lata
Flight distance : 1008297 ft
OK DJI Mindy after waiting for you sweet hart I try to install again the new firm via SD...
This is the result on TXT file:
File on rooth - P3C_FW_RESULT_AB.TXT
========== 2014.01.01 00:01:40 remo-con disconnect======
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
Result: Success.
========== 2016.11.09 09:51:46 =====================
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.07.0090.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
File on H:\MISC\LOG - P3C_FW_LOG_AB.TXT
[00100117]========== remo-con disconnect. boot(1) ============
[00100243]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0xbd5c102a].
[00100278]Packet upgrade start...
[00100314]Packet checking...
[00100364]Packet vlink 01.06.0080 <-> 01.05.0070.
[00100429]Done.
[00100463]Version checking[1]...
[00100502][01 00][00] v1.14.4920 -> v1.14.4920
[00100539][01 01][00] v1.14.4920 -> v1.14.4920
[00100579][04 00][00] v1.44.0.0 -> v1.44.0.0
[00100651][03 05][00] v34.2.0.9 -> v34.2.0.9
[00100731][03 06][00] v2.4.15.5 -> v2.4.15.5
[00100788][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00100866][12 00][00] v5.9.0.0 -> v5.9.0.0
[00100964][12 01][00] v5.9.0.0 -> v5.9.0.0
[00101055][12 02][00] v5.9.0.0 -> v5.9.0.0
[00101146][12 03][00] v5.9.0.0 -> v5.9.0.0
[00101266][11 00][00] v1.7.0.0 -> v1.8.0.0 need upgrade.
[00101369][11 01][00] v1.7.0.0 -> v2.0.0.32, firmware v1.7.0.0 not support.
[00101403][11 01][00] v1.7.0.0 -> v2.0.0.32
[00101438]Done.
[00103473]Waiting for user confirm...
[00113520]Timeout, start upgrade automatically.
[00113587]Firmware upgrading[1]...
[00113629][11 00] Firmware upgrade start...
[00162444][11 00] Firmware upgrade finished successfully.
[00162503][09 00] Firmware upgrade start...
[00188497][09 00] Firmware upgrade finish without reboot.
[00218529][09 00] Firmware upgrade finished successfully.
[00218564]Done.
[00218598]Version checking[2]...
[00218639][01 00][00] v1.14.4920 -> v1.14.4920
[00218671][01 01][00] v1.14.4920 -> v1.14.4920
[00218714][04 00][00] v1.44.0.0 -> v1.44.0.0
[00218805][03 05][00] v34.2.0.9 -> v34.2.0.9
[00218882][03 06][00] v2.4.15.5 -> v2.4.15.5
[00218933][09 00][05] v0.1.1.0 -> v0.1.1.0
[00219017][12 00][00] v5.9.0.0 -> v5.9.0.0
[00219130][12 01][00] v5.9.0.0 -> v5.9.0.0
[00219207][12 02][00] v5.9.0.0 -> v5.9.0.0
[00219301][12 03][00] v5.9.0.0 -> v5.9.0.0
[00219428][11 00][05] v1.8.0.0 -> v1.8.0.0
[00219547][11 01][00] v1.8.0.0 -> v2.0.0.32, firmware v1.8.0.0 not support.
[00219582][11 01][00] v1.8.0.0 -> v2.0.0.32
[00219721]Packet upgrade finish successfully.
[00330095]========== 2016.11.09 09:51:46. boot(15) ============
[00330129]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0xbd5c102a].
[00330163]Packet upgrade start...
[00330200]Packet checking...
[00330241]Packet vlink 01.07.0090 <-> 01.06.0080.
[00330277]Record vlink 01.06.0080 <-> 01.05.0070 (flow = 0).
[00330312]Done.
[00330347]Version checking[1]...
[00330398][04 00][00] v1.44.0.0 -> v1.51.0.0 need upgrade.
[00330432]Done.
[00332466]Waiting for user confirm...
[00342498]Timeout, start upgrade automatically.
[00342584]Firmware upgrading[1]...
[00342665][04 00] Firmware upgrade start...
[00400489][04 00] Firmware upgrade finished successfully.
[00400526]Done.
[00400561]Version checking[2]...
[00400602][04 00][05] v1.51.0.0 -> v1.51.0.0
[00400633]Packet upgrade finish successfully.
[00014264]========== remo-con disconnect. boot(15) ============
[00014369]Packet [C:\P3C_FW_V01.07.0090.bin] detected, card sn [0xbd5c102a].
[00014538]Packet upgrade start...
[00014708]Packet checking...
[00014770]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014824]Record vlink 01.07.0090 <-> 01.06.0080 (flow = 0).
[00014877]Done.
[00014940]Version checking[1]...
[00014992][04 00][00] v1.51.0.0 -> v1.51.0.0
[00015105][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015224][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015258][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015299][01 00][00] v1.14.4920 -> v1.14.4920
[00015331][01 01][00] v1.14.4920 -> v1.14.4920
[00015425][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015504][03 06][00] v2.4.15.5 -> v2.4.15.5
[00015590][07 00][00] v1.0.9.62 -> v1.0.9.62
[00015644][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015742][12 00][00] v5.9.0.0 -> v5.9.0.0
[00015814][12 01][00] v5.9.0.0 -> v5.9.0.0
[00015904][12 02][00] v5.9.0.0 -> v5.9.0.0
[00016039][12 03][00] v5.9.0.0 -> v5.9.0.0
[00016072]Packet upgrade cancelled at version checking.
[00014135]========== remo-con disconnect. boot(15) ============
[00014171]Packet [C:\P3C_FW_V01.07.0090.bin] detected, card sn [0xbd5c102a].
[00014207]Packet upgrade start...
[00014248]Packet checking...
[00014296]Packet vlink 01.07.0090 <-> 01.06.0080.
[00014332]Record vlink 01.07.0090 <-> 01.06.0080 (flow = 0).
[00014365]Done.
[00014398]Version checking[1]...
[00014442][04 00][00] v1.51.0.0 -> v1.51.0.0
[00014558][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014677][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00014712][11 01][00] v1.8.0.0 -> v2.0.0.33
[00014748][01 00][00] v1.14.4920 -> v1.14.4920
[00014781][01 01][00] v1.14.4920 -> v1.14.4920
[00014838][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014922][03 06][00] v2.4.15.5 -> v2.4.15.5
[00015030][07 00][00] v1.0.9.62 -> v1.0.9.62
[00015087][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015177][12 00][00] v5.9.0.0 -> v5.9.0.0
[00015239][12 01][00] v5.9.0.0 -> v5.9.0.0
[00015335][12 02][00] v5.9.0.0 -> v5.9.0.0
[00015409][12 03][00] v5.9.0.0 -> v5.9.0.0
[00015446]Packet upgrade cancelled at version checking.
And on the DJI app Keep showing me that the version is N / A
