Phantom 3 Standard firmware v1.8.10 is now available to download!
salvadorandrade
Flight distance : 109915 ft
fans4c281ddf Posted at 2016-11-11 01:58
Yes it's normal and it's really sounds scary
It does lol, so many horrible stories of bad updates, this one is sure taking sweet time, been stuck at 58% for a while
2016-11-10
salvadorandrade
Update finished, took it for a 20 minutes flight, 316ft high, a little over 400ft distance not a single problem.
2016-11-10
Da Lata
Flight distance : 1008297 ft
Gerardo Rejec Posted at 2016-11-11 00:10
oh.. never mind then... your drone always worked to start with.  I was wondering if this update fi ...
my problem is not with flight, after update I get 1.6.8+ and not 1.7.9...  today I flew 275m distance and 80m High without problems... just on the about tab I get N/A on version
Note. Return to Home was tested OK, PoI was tested OK, course Lock tested OK
2016-11-10
JpNL
Flight distance : 428245 ft
Da Lata Posted at 2016-11-10 22:02
my problem is not with flight, after update I get 1.6.8+ and not 1.7.9...  today I flew 275m distan ...
but the question is:
Had you any problems with the distance and height for the update? (lose signal no video and so on....)
Thats the question ....
because many users were affected, and everyone is updating, but no one reports if it fix the problem.....
(Accept you)
[And are you in FCC of CE]
2016-11-10
Da Lata
JpNL Posted at 2016-11-11 05:27
Had you any problems with the distance and height for the update? (lose signal ...
No problem at all before and after update. I flew two times after update using inteligente flight and on second flight I use RTH without problem! What happens with me is just the firmware version number on the DJI Go App.
If you see my log file you can observe that the update was well done!
I´m on CE mode and today I flew 250m away!
2016-11-10
djordan2
Flight distance : 79291 ft
Well, as I said in an earlier post. I did not see a banner, but went to the firmware download page and installed the new firmware manually with an SD card.  I just went out and tested the Standard.  I do have a Windsurfer on the antenna, but before the update, I could not get more than 2,000 feet out without a RTH kicking in, even with the Windsurfer.  But just now, I flew out of my backyard where there is a lot of electrical interference, such as power transformers, and several very close WiFi station from the neighbors.  Even with all of that, I was quickly able to go out 3,000 feet (914 meters.)  I have never, ever, been able to do that before.  My app still says that I have 1.6.8, but I truly doubt that.  I have tried the ERGtek antennas, but removed then when I could only go out 2,089 feet.  My Windsurfer gave me nearly the same.  I just went out 3,000 feet. Something changed!  I think I like it.
2016-11-10
Rotareneg
Flight distance : 676634 ft
I just had a flight out to 10157 feet (3096 meters) with my P3S on the new 1.7.9 firmware, nice!
http://healthydrones.com/main?share=cLtDZi
Too bad I found stress cracks on one motor mount after finishing the flight, which will be 70 days and 11 total flights since I got it back from DJI service for exactly the same problem. Great job DJI!
2016-11-10
fansb870a553
Puerto Rico
Hi guys, got a quick question, is this update meant for the P3 4k as well or it is only for the standard?
Thanks, luiso16
2016-11-10
Da Lata
fansb870a553 Posted at 2016-11-11 09:39
Hi guys, got a quick question, is this update meant for the P3 4k as well or it is only for the stan ...
Just for standard bro!
2016-11-10
wmcvey
Flight distance : 904364 ft
Rotareneg Posted at 2016-11-10 18:33
ht ...
Was this with a stock setup, or do you have a antenna mod?
2016-11-10
djordan2
DJI Mindy Posted at 2016-11-10 12:24
Could you pleae try to reinstall the DJI GO app?
Then link your mobile device with RC and aircraft ...
I did delete and then reinstalled the DJI Go app. And I re linked the RC to the drone. But I still don't see a notice (banner) to update.  And I just noticed something else. When I go into the app and open "About", there is nothing listed in the Version category.  It just says "N/A". As I said before, I installed the new firmware by a SD card, and the aircraft flew farther than it has ever flown.  I went out just over 3,000 feet before turning back.  I have never been able to go out that far before.  It would be nice if it showed me the new FW in the App, but at this point, I don't care.
By the way, the RTH feature worked as planned.
2016-11-10
Rotareneg
wmcvey Posted at 2016-11-10 20:41
All stock, no mods.
2016-11-10
wmcvey
WOW, stock?? I've been out to 3550 meters, but with a DBS and amps. But on 1.6.8 FW. What where you getting before going to 1.7.9
2016-11-10
Gerardo Rejec
Flight distance : 120141 ft
guys... is there anyone who had prevoously problems with the standard range limit to 50meters that now has been solved? those specialy in european countries...  do u guys still have the problem of range? (50 meters only)????
2016-11-10
Rotareneg
2585 meters was my previous best: http://healthydrones.com/main?share=GejnKp
2016-11-10
fanscd256e3f
Flight distance : 175495 ft
I am on  3.01 Galaxy S7 I do have the banner but I'm waiting till I get more feedback don't want any trouble 4 glitches I have 1.6.8. And for me it works flawlessly I couldn't dream of a better working machine
2016-11-10
fans825c0532
Flight distance : 341355 ft
So, people who reach over 500 m... please state your altitude, and setting.
It seems, most people are able to get at least 1000m distance when they are up 90m > altitude.
For me, the furthest I have been without any laggy video, was about 300m away, but I was at a slight 5 -10 m slope and i flew my p3s up the small hill. I had VLOS .
Altitude was 50-55m up. In a usual neighbourhood setting.  At 310, "no signal" - and then option to RTH popped up. I selected it and operation timed out.
I still had RC control of the drone, so I flew back towards me.
So I think.. 200m is already quite far away. Just not as strong as Advance of course.
Uhhh
also, app should be latest. But Drone is 1.5.70
Those are my findings/ experience.
I had had stress cracks before and it was fixed by DJI. One push factor about P3 is the possible stress cracks.....
Thoughts?
I am not planning to upgrade unless it is proven by number people who update to 1.7..... that signal loss , video transmission etc... are better than what I have right now.
I think.. If I flew at 80 - 100 M height, I could probably also have up to 1000m distance from take off.  - That is my hypothesis.
But because I am not currently in my Home country, I don't plan on updating.. as everything is working fine right now .
2016-11-10
TheTan
Vietnam
stable, very good!
2016-11-10
DJI Natalia
djordan2 Posted at 2016-11-11 10:56
I did delete and then reinstalled the DJI Go app. And I re linked the RC to the drone. But I still  ...
Have you tried to connect it with an IOS device since you upgraded it with an android phone?
Glad to hear that it functions well as planned.
For your android phone, you could restart the phone and check again later.
2016-11-10
DJI Natalia
Da Lata Posted at 2016-11-11 07:16
No problem at all before and after update. I flew two times after update using inteligente flight a ...
Glad to hear everything functions well, for the version number on "About" page, please help clarify what mobile device you are using to connect the remote, have you tried another IOS device or Android device?
2016-11-10
fanscd256e3f
Devildog9999 Posted at 2016-11-10 08:22
Same here - tried every which way, and no banner on 1.6.8/3.01(8)
@DJI - Is there anywhere to get t ...
I have the banner and I never connect the phone to the Drone
2016-11-11
fanscd256e3f
I have the banner for update I'm not using Wi-Fi only my phone service I don't have any Wi-Fi service at all an unlimited service on my phone I'll wait to update to see what the word is but I do have the banner turn your Wi-Fi completely off on your phone then open DJI app
2016-11-11
fanscd256e3f
DJI Mindy Posted at 2016-11-10 10:44
Please try to link RC to aircraft and connect your mobile device with RC first then check the curr ...
I noticed the banner the other day when I opened the app to use the form
2016-11-11
Da Lata
DJI Natalia Posted at 2016-11-11 15:56
Glad to hear everything functions well, for the version number on "About" page, please help clarif ...
My devices are an Samsung J5 and Samsung S6 and I try both with same result. DJI Natalia did you see my log files on post #74?
Is everything OK with then?
2016-11-11
Betamace
Flight distance : 2133 ft
djordan2 Posted at 2016-11-11 07:20
Well, as I said in an earlier post. I did not see a banner, but went to the firmware download page a ...
Have you looked into the P3C_FW-LOG_AB.txt file for the most recent upgrade successfully performed  and see what version it installed? I have 1.6.8 installed and tried to upgrade to 1.7.9 via SD card but it stops at version checking. I've never had FW version reported in the GO app settings/about.
2016-11-11
DJI Natalia
Betamace Posted at 2016-11-11 17:28
Have you looked into the P3C_FW-LOG_AB.txt file for the most recent upgrade successfully performed ...
For phantom 3 standard, there is no need to put the bin file into SD card to get it upgraded, we can upgrade it through APP directly.
May I know have you tried to delete APP, reinstall it and upgrade it again?
2016-11-11
fansdcf34e53
Flight distance : 158675 ft
I have the same problem. My first ver is 1.5.7. I see the banner with upgrade to 1.6.8. Upgraded. Now in DJI GO, in version section i have information: N/A (no information about version).
Updated with successfully, but still i haven.t information abt new version 1.7.9 I tried everting. {:4_142:}
2016-11-11
fansdcf34e53
In my case: I tried everything: restarts app, restarts wifi/reconnection, deleted files in my phone (dji go pilots).....My system is Android 5.0.2
2016-11-11
fans943c424a
Flight distance : 229911 ft
fansdcf34e53 Posted at 2016-11-11 04:40
I have the same problem. My first ver is 1.5.7. I see the banner with upgrade to 1.6.8. Upgraded. No ...
Had the same " upgrade to 1.6.8" prompt but ignored it. I shutdown drone, controller and app. Restarted everything and the next prompt I got was for 1.7.9 Selected the upgrade which went well. Still grounded though due to weather.
2016-11-11
djordan2
DJI Natalia Posted at 2016-11-11 15:54
Glad ...
I did all that, but I still don't see the Banner or the 1.7. showing in "About" on my Android App.  Only did one test flight last night, and it was great.  I will test more this evening after work.  If I remember correctly, my first test flight was at 190 feet and went out 3,000 feet.  That's the best I've ever done with the Standard.
2016-11-11
fansdcf34e53
I found solution for banner with new update :-) Please change your phone fm android to iOS system :-) I was tested new firmware and my max dist. is 500m without errors :-)
2016-11-11
Ice Nine
fansdcf34e53 Posted at 2016-11-11 10:08
I found solution for banner with new update :-) Please change your phone fm android to iOS system :- ...
Id rather chew aluminum foil
2016-11-11
Devildog9999
Flight distance : 73865 ft
For me personally, there seems to be an issue with Android.  I threw DJI Go on my work IPhone and it went through 1st try.  Everything shows correctly on the Iphone as well.  On my Android all I see is N/A for firmware version.   Hoping to test it today and see if the issues are fixed.
2016-11-11
fansdcf34e53
Devildog9999 Posted at 2016-11-11 18:23
For me personally, there seems to be an issue with Android.  I threw DJI Go on my work IPhone and it ...
Yes. I was the similar situation My max distance - 500m achieved without modification (in CE mode).
The previous version 1.5.7 sometimes i was "Low Signal" but still to 500m. Today, on 1.7.9 without any errors/msg. Without any modifications.
So if you don't have banner with update on Android, please use iOS system. Good luck!!!
2016-11-11
harry0112
Flight distance : 167651 ft
Peru
Two weeks ago I have a problem with my phantom 3 standard, I eh flown and when I get to 80 meters distances the app starts to say lost signal and then returns home, I vole in rural areas to make sure that no no interference. I mind flying above 800 meters away and everything was fine. What's going on? help me!!
2016-11-11
Gerardo Rejec
harry0112 Posted at 2016-11-11 12:52
Two weeks ago I have a problem with my phantom 3 standard, I eh flown and when I get to 80 meters di ...
dawnload the last update and try it
2016-11-11
ontwowheels
Flight distance : 434626 ft
I received the notification here, downloaded but have not updated yet.
2016-11-11
ontwowheels
djordan2 Posted at 2016-11-10 18:20
What exact Windsurfer are you using if you don't mind me asking?
2016-11-11
ontwowheels
Ice Nine Posted at 2016-11-11 11:23
LOL....I am an Apple and Mac fan but it's still funny.  ;-)
2016-11-11
fansb870a553
Puerto Rico
Da Lata Posted at 2016-11-10 21:41
And what are my options if I have the same disconnect issues that people reported here!!!
I wished there's a dedicated forum for the P3 4k......
2016-11-11
