Flight Controller Serial Number
15345 7 2016-6-9
alanatabz
Flight distance : 29459 ft
Hi
I don;t appear to be able to see my flight controller serial number.
DJI GO APP > Settings>about
If flight restrictions for geofencing are removed, does this change to N/A?
all it shows is N/A   a few days ago it had a number,that you reference to unlock. now it doesnt.
Any help would be great
2016-6-9
alanatabz
Resolved
The cable between the controller and Ipad was faulty.
Replaced the small coily cable bough on Ebay wit an original Ipad one.
2016-6-15
Donnie
Flight distance : 3636782 ft
alanatabz Posted at 2016-6-15 04:57
Resolved
Those cables are a real Bugger sometimes,  glad you found the issue.
donnie
2016-6-15
curso88
Flight distance : 184852 ft
Same problem. But not is the cable. Is the stability in the USB connection data.  Same new cable some times work sowing the flight controller serial number and unplug and plug and not sow this serial. Any advice?
2016-8-3
DJI-Jamie
Flight distance : 112405 ft
curso88 Posted at 2016-8-4 13:13
Same problem. But not is the cable. Is the stability in the USB connection data.  Same new cable som ...
If this is an intermittent issue, it could be an issue with the USB cable or the USB port itself.
2016-8-4
rickb33952
After I completed update to 1.6 controller firmware update, I experienced:
1. Update Controller message required update two more times with completion requesting controller reboot.
2. After third try I left the controller on and after about 10 minutes of waiting while exploring I took a picture of the screen "About" showing version unrecognized and Serial N/A.
3. After another 5-10 minutes, checked back and the About now indicated Version 1.6.0 and Serial N/A
4. After another 5 minutes or so, I checked back by selecting About and the Version and a Serial Number was revealed?
I have no idea why this happened but it definitely was not a cable or USB connector.
Perhaps DJI could take a look at this and comment.
2016-9-12
DJI-Jamie
rickb33952 Posted at 2016-9-12 22:30
1. Update Controller mess ...
It may be a potential server issue, since the serial number did reappear eventually. To clarify, does this also occur on the RC's current 1.7.40 firmware as well? What firmware are you running on the aircraft?
2016-9-12
Skyborne4D
Flight distance : 573970 ft
Good Morning to all,
I tried only opening DJIGO on my device only seeking my flight control serial number to no avail.  After attaching the necessary cords and readying my drone for launch I was able to then visit the About section within the app and see my FCSN.  You need to allow your drone to connect to DJIGO in order for it to identify the FCSN.
Good Luck!
2016-11-18
